poly bush vs original trailing arm bush
How much difference do the powerflex trailing arm bushes make on a 2wd cosworth? Mine had been changed to poly bushes years ago. I have heard that there are remanufactured originals available and they are better because the are a ball joint. Has anyone switched back from powerflex to these original spec bushes and was it worth the cost?
I could never understand why people did this? I'm sure ploys were ok on an 1800lx?
Put the bearings back in (decent used trailing arms will prob be easier/alot cheaper) and while you're at it put some solid beam mounts and one of those msd diff mounts on.
You'll be amazed at the difference.
Worth the cash then... I have the arms out at the moment stripped for powdercoat etc. I will buy the original spec bushes. I was thinking about turning up some solid mount beam bushes anyway and a new diff mount is on order. Cheers.
Received 1,044 Likes
Ive spoke to a few people about rear arm bushes. The people with poly bushes said they couldnt tell the difference between poly and standard.
I spoke to a few people who said poly bushes are a no no.
I bought a used pair of arms and carefully remove the seals. I removed the old grease and repacked the bushes/bearing.
With the std beam setup its got to be the only way of making sure the rear axle isn't moving/twisting under load or braking
Cheers again guys. The replacement standard one are pretty pricey. If I do make new solid beam mounts and fit the new billet/poly diff mount will the trailing arm bushes still make a huge improvement over powerflex?
