Injector loom testing!!!
Old Aug 23, 2014 | 07:01 PM
doga-ot's Avatar
doga-ot
Default Injector loom testing!!!
Right got an BOA injector issue and I suspect it the injector loom fried, without buying a noid tester is there anyway I can safely test it without frying my ecu. I have heard something about an led bulb but not sure how or what to do, any help appreciated...........
Old Aug 23, 2014 | 08:09 PM
stevieturbo's Avatar
stevieturbo
C**t
What exactly are you trying to test ?
Old Aug 23, 2014 | 08:11 PM
doga-ot's Avatar
doga-ot
injector loom as its a prime suspect and a common fault on the boa as they tend to melt due too where they are run in the factory
Old Aug 23, 2014 | 08:14 PM
stevieturbo
C**t
That didnt really answer my question.
Just use your eyes and a multimeter either way.
Old Aug 23, 2014 | 08:23 PM
doga-ot's Avatar
doga-ot
I have fuel too the engine, I have spark and will fire up with easy start for few seconds, been told by 6 reputable people it is an injector loom fault! As I said it looks can be deceiving.
Old Aug 23, 2014 | 08:31 PM
stevieturbo
C**t
So once again, what exactly are you trying to test ?
"Loom" is very unspecific.
Old Aug 23, 2014 | 08:52 PM
studabear's Avatar
studabear
continuity check and resistance check at each end of every wire would be a start?
Old Aug 23, 2014 | 09:06 PM
doga-ot's Avatar
doga-ot
want to check the injector looms not fucked I know shit all about electrics
Old Aug 23, 2014 | 09:29 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
if you are trying to see if the injector earths are pulsing,
that doesn`t tell you they are squirting fuel,
removing them from engine and hooking up to the fuel rail would do 2 tests at same time, but yes you can probe the wire on each injector to check if its pulsing, by slipping a probe with a test light, into the back of the plug on each injector plug
, I believe the live is constant to each injector with ignition on, and the earth wire is pulsed by the ecu
Old Aug 25, 2014 | 07:24 PM
costina's Avatar
costina
Live long and prosper!!
Wes what injectors u running
Old Aug 25, 2014 | 07:31 PM
GVK.'s Avatar
GVK.
This type of thing makes me laugh.
I don't know shit all about repairing TVs so I leave it to someone that does.
Old Aug 25, 2014 | 08:59 PM
doga-ot's Avatar
doga-ot
Standard BOA injectors
Old Aug 25, 2014 | 09:01 PM
doga-ot's Avatar
doga-ot
That someone never came and i want car sorted so it can get in body shop
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
muz
Sep 30, 2015 08:29 AM
