Cosworth Fan Loom Help
hi guys, ive knocked up a new loom for the fans, and i cant get them to work on a switch in the car. can someone just confirm what wires go to which realy pins? and where do i plum in the in car switch?
cheers guys.
cheers guys.
Yep just like the link, one side of your overide to earth , the other side to earth on the relay (switch) usually pin 85.
The diagram in the link uses as permanant live for relay/coil side usually 86(standard wiring) so make sure you have turned your overide off before you walk away or you could end up flattening the battery.
A toggle switch with a light would be a good bet to eliminate this happening or just dont forget like I would haha.
big_Rad
15-09-2017 09:36 AM
muz
16-08-2015 12:57 PM
