ratchet on clutch pedal has gone on erst
went to go out yesterday and managed to get about 100yards down my road and went to change gear and the pedal just went down and stayed down had to put it in reverse then start it up and reverse back to where i park my car.took the pedal off and the bushees in the pedal had broken up so the pedal was sitting at a little bit of an angle,changed the bushes and put it all back together today then went out for a drive and it happened again had to limp it home in 5th at 20mph,im going to be rushed off my feet thursday evening when i finish work,got to do a service on the erst and also do the valve stem oil seals and now the clutch pedal,im going away friday after ive finished work so its all got to be done thursday,i think im going to be out there with a lead light
Time to take out the drivers seat & stick your head & hands under the dash for hours on end only to have a bad back & neck the next day
ORRRRR you can do what i done & just change the whole pedal box - it's much easier
I used one out of another RST but i fitted a new ratchet in while it was out was a piece of piss!
Im quite sure you can use a normal mk 4 escort one too
oh right fair enough,ive got a new ratchet kit ordered and picking it up 2morrow and going to get it all done 2morrow evening so i can go away at the weekend,so the seats got to come out again and go to work friday morning with the bad back and sore head from the pedals
Just fit a pedal out of a Mk5 escort, the pedal is adjustable so you dont need the ratchet.
See - http://www.apracing.com/roadcar/clutch/epmods.htm
Mc5506
05-10-2015 09:57 PM
