MK1 FRS gearbox conversion on silvertop
Currently carrying out this conversion on my mk2 xr2. Fitted new clutch, flywheel and slave cylinder today and got the starter motor fitted.
Offered up the two piece shaft from the mk1 FRS and the bracket for the shaft bearing must bolt onto the sump of the blacktop, I'm using a silvertop block so there isn't anywhere to mount it on my sump.
Has anyone else done this conversion on a silvertop so I can see how they have dealt with this?
It looks like I'll have to fabricate a bracket that mounts to the block to sort it out.
Grant
Grant
Grant
Grant
yes mate all 2.0 mk2 mondeo..the mount and centre shaft are as ford made them,the two small shafts are mondeo on the left sides and frst on the right sides
