Solar powered battery chargers, any good?
IM thinking of getting one, not to charge a flat battery but to stop my existing battery from going flat.
My car sits without being used for months at a time and the battery keeps going flat.
I want to keep it and the car alive so the alarm still works while it's parked up.
Are solar powered chargers any good?
What do you recommend?
I was thinking something like this
http://www.ebay.co.uk/itm/181392046339
Yes they work really well. Friend of mine uses one on his car that sits in the garage and comes out on the occasional sunny day. He was forever killing batteries but not had a flat since.
Modern solar panels don't even need to be in direct sunlight, they work at the full efficiency in just daylight.
Don't forget if you are plugging it into your cig lighter socket and the power to that goes off when the ignition is off, you will need to connect it straight to the battery.
Fleet Manager
I work with motorhomes and caravans and they have now become standard fit to better models I use one on my car that dosent even need a solar regulator it's saving my battery
And it was only 34 quid, you get what you pay for cheap eBay stuff puts on like 1ah mines se size and dose 2.8ah
Living in Prestatyn I can see why you work on the motor homes and caravans, was there last weekend at priest haven sands..
Where did you get you 2.8 mAh from? I'm looking For one for a project of mine so would be interested to lay my hands on one
track.focus'd
12-08-2015 05:53 PM
