Transit connect Help
Old May 1, 2014 | 12:26 PM
rs milesy's Avatar
rs milesy
Default Transit connect Help
Been asked to look out for a transit connect for my nephew, budget is not massive between £1500 and £2000, I could do with some tips on which one is better one as I have seen TDCI and TDDI, all done the miles though, what should I be looking for in the way of problems ?
Thanks in advance.
Old May 1, 2014 | 05:49 PM
Check the sills they can rust. Also check the coolent level sometimes the thermostat housing leaks (easy fix). The connects are a really good van. I work on them most days so I know a bit about them.
Old May 1, 2014 | 06:32 PM
dojj's Avatar
dojj
Resident Wrestling Legend
intercooler hoses and headlight bulbs are a bitch to change
Old May 1, 2014 | 08:23 PM
There both easy to replace Dojjy.
Old May 1, 2014 | 08:42 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
+1
Old May 3, 2014 | 05:07 PM
rs milesy's Avatar
rs milesy
It was more the mechanicals I am concerned with, which is the better engine, injection system ?
Old May 5, 2014 | 01:37 PM
cossiegreg1's Avatar
cossiegreg1
I've had both, i would choose TDDI all day long.
Old May 5, 2014 | 03:32 PM
dojj's Avatar
dojj
the hoses we had loads of issues with them little hooks they had in the hose clips which didn't come with the newer canvas hoses that replaced ALL the split rubber ones
and changing headlights, we gave up because there wasn't enough space to get your hands in there
Old May 5, 2014 | 04:45 PM
Both the tdci and the tddi have both been good in the fleet at work.
The tdci is the quicker van.
Old Jun 29, 2014 | 12:04 PM
woolf's Avatar
woolf
Injectors can be an issue,put it under load in top gear and see if it cuts out and glow plug light flashes.These injectors need coding from 2003 - 2006 and aren't cheap
Old Jun 29, 2014 | 08:54 PM
CHRISP's Avatar
CHRISP
sod the connect and go back to the bullet proof escort vans
http://www.ebay.co.uk/itm/1713480944...9#ht_82wt_1141
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
Neil Clark
21
Oct 1, 2015 07:02 PM
stevecfrst1
Sep 30, 2015 05:18 AM
