Sapphire front & rear bumper removal >
Hi All,
Looking or some advice (and pics if poss!)
Both bumpers coming off soon for a respray but I've heard some horror stories about height adjusters ? (particularly on the front) ?
Any tips or pointers greatly appreciated !
Thanks,
DW.
Thanks,
DW.
The bumpers are a piece of piss to remove.The adjusters will have probably seized up,after all once they were fitted there is not a lot of need to mess with them.
Take the adjusters off the bumper and heat them up.A small gas torch will do.They will soon become free.
Rear bumper,put your hand at the bottom of the quarter up behind the bumper.There is a bracket on either side.They just turn maybe a quarter of half turn and pull out.Iirc then its bolted on in the boot floor.Undo slide out.
The front is where you may have a bit of a problem.Access is easy but like you say its only held on in two places.Same as back side of the bumper stick your hand up but they are bolted on at the front.Many sieze up or are rounded or snap or the whole thing turns and you have a hole in the wing after
.Oh dont forget to disconnect the front fogs.
Once you have them off its easy to see the adjusters and how to get them off to free them up.Also once the front one is removed the two adjusters sit in the chassis rail.Dont lose the rubbers .
You can get alloy replacement brackets for the front off Jimmy on here I think.
Try not to break anything
Well my last one they just turned and turned.Left a mega hole in the wing ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
It was also pikey'ed on with spaced out long wood screws ffs !.
No I didnt do it either.God I remember doing this probs 18 years ago.At that time though the brackets were readily available from Ford.
To the op if you still cant get ya head around it have a quick look in the restoration room.There are loads of pictures showing bumpers off where the cars are having bodywork done so you can see the mounts etc
track.focus'd
12-08-2015 05:53 PM
paceo
12
04-08-2015 08:50 PM
