fault code p0131 help
Old Apr 23, 2014 | 07:43 PM
st220kyle's Avatar
st220kyle
Default fault code p0131 help
got the above code on our sportka saying:
(0BD II P0131 Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 1)
what exactly does this mean? I cleared it and it went away, but does it mean the sensor is faulty? The same thing happened about a year ago and never did it again until today.
cheers for help
Old Apr 23, 2014 | 07:50 PM
RichieST's Avatar
RichieST
Yes, usually means the pre-cat lambda sensor is knackered.
STAFFY OWNER's Avatar
STAFFY OWNER
Most likely one of your lambda sensors is buggered, I thought the fault code usually indicated whether it was pre or post cat.
Bugger, beaten to it by Richie.
Last edited by STAFFY OWNER; Apr 23, 2014 at 07:53 PM. Reason: Too slow with my one finger typing.
Old Apr 23, 2014 | 07:54 PM
RichieST's Avatar
RichieST
Bank 1, sensor 1 is pre cat, bank 1, sensor 2 is post cat.
If it was a V6 and had 2 manifolds with 4 sensors for example, it would be bank 1 sensor 1, bank 1 sensor 2, bank 2 sensor 1 and bank 2 sensor 2!
Old Apr 23, 2014 | 07:56 PM
STAFFY OWNER
Aaah I see, cheers for clarifying mate.
Old Apr 23, 2014 | 08:19 PM
GVK.'s Avatar
GVK.
There was a TSB for these years ago where the pre-cat (upsteam) HEGO (LAMBDA) sensor is replaced and a PCM software update to cure this.
If the software update wasn't done with the modified sensor it could cause premature failure of the sensor/driveability issues.
TSB 67/2006
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
