Using Fiat P8 ECUs?
Wye Valley Hardcore
Using Fiat P8 ECUs?
Can Fiat 16v Coupé P8 ECU's with the code IAW 4Q4 be used in place of IAW 048/P8 Cosworth ECU's.
I think the 4Q4 is the non turbo and the 4WF the turbo.
I have a Pectal P8 baby board to go in it and would need a new chip anyway. The loom would be a brand new job if the pin outs aren't quite the same.
Martin
Wye Valley Hardcore
I've found the pin out details for the 4WF Fiat Turbo ECU and they are practically the same as the Ford one and could be changed quite easily. However, I can't find any data on the 4Q4 Fiat non turbo ecu.
Wye Valley Hardcore
Well, according to that website, all P8 ECU's have the same pin outs then manufacturers used to the Aux outputs to their own discretion. All P8 ECU hardware should be the same then, whether it be off a turbo model or not. It's just the chip and loom which would be different, neither of which would be used anyway.
Martin
you cant use P8 from fiat or lancia....
wiring is same but...there are differences in PCB..
stripped PCB is same..but there are differences...
fiat has differend impedance injectors and fiat has hall sensor on CAM...
cosworth has VE sensor.
But cossie is still alive
I am dealing now with same problem...trying to make P8 fiat work with cosworth...
P8 fiat ecu cost 30EUR P8 cosworth cost 500Eur...
difference is not so big....
NC53
13-09-2015 04:05 PM
