Esc Cos Problem - Cuts out once warm
I own a large turbo escort cosworth with a problem.The problem is that when I start the engine cold it starts ok. Let it idle to the normal temperature about 15minutes and it just cuts out. If I try to start again,it wont start. Engine cranks properly when starting. Let it "cool" about 5 to 10 minutes and it starts just like nothing ever happened. The prolem also appears when hot,after driving. I park the car,come back in about 10 minutes, try to start and wount start. When starting from cold no problems,always starts up properly. CPS sensor has been change today, but to no avail. Also tried a Coil, but again, car starts fine, then cuts out once warmed up.
I have noticed that when I turn the car to ignition, the sensor that is located to the right of the engine and is light grey in colour (located by where the boost hose goes into the engine, next to throttle cable) this clicks quite loudly and quick..
Any ideas as to what the problem could be as its eally starting to annoy me!
Thanks
Thanks
to be honest, i havent got a clue what im talking about spadge
Dilly - cheers, but not what we wanted to hear
was hoping it was this sensor that was the cause
Spiky - it looks abit different to yours
See the yelow plug on yours, just above the throttle cable, that was the one making strange sounds
Just lovely when we picked it up, but saying that, we were on the M1 pretty much straight away, so kept cool.. went in slow lane for abit, then it must have got warmer and died
left it for 5-10 mins and started... then later died..
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
cheers spadge... so tomorrow morning will be checking that.. Is there a way to check the actual sensor to see if its faulty? Or is it a case of putting a different one on?
IE driving round yours tomorrow and buying one
Would this sensor make the car cut out after a certain point in that it reaches a certain temp?
Thank
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
might have a cold, but still got your sense of humour
Now that you mention it tho, does make sense
Would this Sensor currently be in stock at Spadges Emporium ??
If you come for it on Easter Sunday just make sure you bring me a big fook off easter egg or or you will get is a slap
changed temp sensor, still no joy
top marks for are residant RS Parts man, Spadge!!!
Full of fever, bank holiday Monday, yet still able to supply parts when in need... Thanks again mate, REALLY appreciated that
Hope the Easter was alrite
![Content](https://passionford.com/forum/images/smilies/content.gif)
Shame it didn't sort the problem but i guess its another thing off the list
While the engine is running, grab hold of the ecu and shake it !
Dont tug on the wiring loom too hard.
If the engine cuts then it could be a faulty ecu/dry joint, a fault connector pin or
a broken wire in the wiring loom.
Needle in the haystack I am afraid....
