Tremec TKO 600 users
Happily retired
Well, it should'nt and it will affect your bearings if it does. A lot of these have been returned to Tremec and replaced by new units.
In my opinion; these should all be fitted with the modified linkage finger and carbon fiber reinforced syncro rings as this greatly improves the transmission. The syncros can take more beating as well as slow the gears down faster, allowing for quicker gear change. These transmissions are known to be almost impossible to get into third gear at higher revs without this mod.
Even shifting normally into 5th is also a problem on these (without the mod).
As Rod stated above, his sounds terrible, but doesn't have any problems with gear changes. His has been in the car since 1999 if I remember correctly. Check this clip on Youtube
FAST AUTO SIERRA COSWORTH 331 KM/H
Happily retired
If you click the pic in my first post you can hear it in all its glory as it slows down.
Todays TKO should not make any noise. If it does then there is a preload or meshing problem with the box, this also happens with *some (rarely though) newly built T5s, sometimes you just have to find the sweet spot to make them stop sounding shit. The blueprint is the same, sizes are just larger for the TKO. Just talk to any of the Tremec dealers in the US and you get the same reply, especially the ones who modify them like libertygears and ampperformance.
Happily retired
JK12
33
26-04-2021 12:09 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
