Engine Help! (with pics)
Old Mar 26, 2005 | 11:37 AM
FAST AS FORD's Avatar
FAST AS FORD
Default Engine Help! (with pics)
The cambelt tensioner on my g/friends car has spat out its bearings causing the unevitable piston valve contact! Its gunna need 4 new exhaust valves, the inlets look ok Im not sure ifthe guides are bent tho, whats the best way to check? Heres a pic
Also theres some contact marks on the pistons, iwas thinking of just sanding them a bit coz the crank turns ok and theres no marks on the bores, what do you think?
Any advice would be greatly appreciated before we shell out on new bits!
Thanks [/img]
Old Mar 26, 2005 | 04:50 PM
FAST AS FORD
Anyone?
Old Mar 26, 2005 | 04:54 PM
mike77cos's Avatar
mike77cos
I wouldn't have thought you'd bend guides, take the valve spring off, and see if they slide nice, I'd of thought so, you got to be VERY unlucky to bend guides
Old Mar 26, 2005 | 04:55 PM
NUTS RuS's Avatar
NUTS RuS
I usually just slide down a new valve and give it a rock about to check if its okay. And If it were mine I wouldnt worry about the pistons either. New valves will need lapping in so you should be able to tell from the fine grey line it leaves if they are seating okay
Old Mar 26, 2005 | 05:03 PM
FAST AS FORD
Cheers Will get hold of some valves on tues when the shops are open.
How do you "lap" the valves in?
Old Mar 26, 2005 | 05:06 PM
mike77cos's Avatar
mike77cos
grinding paste, and a stick, buy both at a motor factor, first course, then fine in a trying to start fire motion, until there is a grey ring around the valve seat! it takes time to get it right!
Old Mar 26, 2005 | 05:08 PM
NUTS RuS's Avatar
NUTS RuS
Valve grinding paste and a lapping stick
Put some on the seat of the new valve and a couple of drops of oil and lap away. Turn the valve a quarter of a turn every so often until the new valve is seating correctly all the way round
FAST AS FORD
ar, i get it, nice one
Old Mar 26, 2005 | 05:09 PM
mike77cos's Avatar
mike77cos
Some how sounds better than the way I put it!
Old Mar 26, 2005 | 05:15 PM
NUTS RuS's Avatar
NUTS RuS
We have things called lighters up here to start a fire
Same thing tho .... "lap away" and
Dont get any paste onto the stem of the valve whilst your doing it either - but a drop of oil helps
Old Mar 26, 2005 | 05:16 PM
mike77cos's Avatar
mike77cos
Ha ha funny guy
But soooo right
Old Mar 26, 2005 | 05:50 PM
richm's Avatar
richm
Default Re: Engine Help! (with pics)
other way round, surely? Inlets bent, not exhausts..
if the seats in the head look clean, go straight for the fine lapping paste and see how it goes, may save a chunk of time and effort. The poo paste that factors usually sell is lumpy and fookin lumpy anyway, "fine" is usually a matter of opinion.. lol
JoeyBoyden
Jan 4, 2024 02:36 PM
bigryrs
Mar 28, 2016 09:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
