Focus ST fault code p0240?!
Old Mar 26, 2014 | 07:33 AM
DonMarsh's Avatar
DonMarsh
Default Focus ST fault code p0240?!
Hi everyone I have a 2009 focus ST 2 which iv owned from new the car has covered just 30k miles, just recently the engine management light has come on using my dreamscience handset iv read the fault code p0240, I then took it to an approved ford repairer the same place that does my servicing they said the oil filter housing needs replacing as the cills are gone and it's been creating a vacuum in the engine and are weak point on the car, so they replaced it and reset the light. 200 miles later light is back on and it's the same code again, iv been looked online and it seems like it could be the maf sensor?!
Any ideas people?
THANKS
Old Mar 26, 2014 | 08:04 AM
RichieST's Avatar
RichieST
Check the hose that goes from the filter housing, up behind the inlet manifold and into the top of the cam cover. Some are plastic and the corrugated section is prone to splitting. It's very easy to break when changing the filter housing. There is a updated part that is a rubber hose instead.
Old Mar 26, 2014 | 06:29 PM
GVK.'s Avatar
GVK.
If it's not as RichieST says, p0240 is a boost pressure sensor code (MAP sensor)
DixieTheKid
Sep 14, 2015 09:04 PM
Si B
Sep 12, 2015 06:49 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
