2wd hydraulic clutch conversion?
The annoying ginger guy
There's no easy way with out the hard work being done first either fit an external slave which requires the mounting braket welding on or fitting a centrifugal slave from a Mondeo or similar but that needs the box out and lining up the slave, I was going to use a mini copper(BMW) slave and master as you can run a feed from the brake reservoir, but there are a few options now days
cossie fan (unluckerly)
I'm going to do mine but straying towards a rayland kit now as it's tried and tested!
The only thing that worries me with doing it my self is what stroke master and slave do you use? If you use one that pushes to far on the clutch cover you can damage it also could give a funny clutch bite hight if wrong bits used
Ha ha I'm fine with hydraulics mate what ever kit I buy will be as easy as pumping a tyre up compared to fitting a slave on an xf95 in the dark and wet and then bleeding the cunt up lol
Lol I know your pain I get the odd shit now and again, I've got a draw full of different slaves trying to find the best, so far I find the best are the centrifugal slaves from a Mondeo but don't want the be dealing with it if it fails and have to pull the box back out
I'd be happy using a bmw master and landrover slave if I new what stroke slave to use! But with having to mod the pedal box as well I think fuck it just get a rayland kit it's all there
