Car colour code wrong ?
Hi All
i have recently purchased a ford fiesta van 56 plate
i need to touch up some paintwork and according to some websites my colour code is ivory blue, although the car is very much white! all the v5 says is white. im not bothered if it has been resprayed at some stage although it doesnt look like it has as i have had the carpets out which are white underneath.
anyone have any idea if this colour code is correct?
Many thanks
Many thanks
cant confirm but colour names sometimes bear little resemblence to the actual colour.. If the car's basically white and the V5 says white then I would not worry about that..
in my experience main dealers take everything off the chassis number anyway that way they know exactly what paint was applied to the car when it was built. If you do a free / cheap HPI check it should show a colour change if it was registered with the DVLA.
My Yamaha is white yet is has blue in the offical colour name.. try googling the colour code and see what comes up..
HTH..
HTH..
The code is most likely just 'h' or '7' mate, its not always both digits. However if you search just one letter/number it will bring up loads of possibilites. I can search on my scheme for you tomorrow if that helps? Btw it will almost definatley be frozen white as its the only one the did in that era on vans
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
