konis and ahmed springs, with adjustable top mounts, and rear spring discussion.
As above really, Is it possible?
I want to run eccentric top mounts to gain a load of castor, but i want to keep with konis instead of running coilovers.
most adjustable top mounts fit under the turret and are flat rather than fitting into the raised section in the centre of the standard turret, so i guess the top spring platform is lowered and the ride height increased?
Sponsor
What you have to remember is there budget shocks pete not a what you would call a good setup for a fast road car with power
Edited to add no cossie handles superb most handle like a sack of shit free falling down a ski slope
Well they've always been bang on on my Cossies Jay so i rate them, you should have driven mine on the coil overs, if Sheady reads this I'm sure he'll agree, fooking terrible to say the least, Tarren never drove the thing so he knew fuck all he was just happy it was slammed
I agree with both of you to be honest, konis aren't the best, but i would rather stick with konis than cheap coilovers. they will be changed at some point but it will have to wait a little while yet as if im gonna do it i will do it properly not just gaz or avo coilovers, i want something that will actually absorb shocks instead of loosening the fillings in my teeth
so back to the original question... i guess there is no problem with shortening the spring to compensate for the increased height from lowering the top mount. the only downside is losing some suspension travel.
cue everyone saying it is dangerous to cut springs...
I had gaz coilovers on my old saph and once the spring rates were changed it was a decent road car, the rears are far to hard as standard I couldn't get any weight transfer and no grip.
Sponsor
because the of the shelf are not sprung and valved for the correct weight and use
Abetter idea would be to have the car weighed and then phone gaz up give them the car weights and a description of how its used ! This should add no extra cost
I will be doing the above and buying bilstien or if i can get the extra budget ohlins
Sponsor
If you know the lengths and widths and poundage falkner springs will make you some for a koni shock
Eventually the spec will be:
coilovers, probably ohlins or similar, valved and sprung correctly so i don't damage my back when I run over a stone in the road
comp struts,
3dr hubs
adjustable tcas
wrc style bladed front arb
probably escos rear arb
there's a good couple of grand there
Do you know what your setting was on caster before and after adding the spacers?
i dont sorry, i just added the same both sides as a trial to see what difference it made. It made the car more stable at speed, which was what i was aiming for, and then i crashed it before i had chance to go any further with doing a more permenent job.
Ah, shame, I guess it might have been at nearly 4 degrees if you'd got enough spacers/washers. Standard with an H14 is supposed to be about 3 30'
For what you use you car for the Koni's offer the best ride.
Mark
Okay so I might have a plan for the fronts, got to wait for some bits to arrive and do sone measuring.
On the rear, ive checked the springs I have, and they are 300lb/in. ( checked in a press with a corner weight scale under them.)
I am actually assuming that the rears are ahmed spec springs, I bought them second hand but the car has always driven well on them and it sits nicely.
Sooo... if I were to contact faulkner springs as Jay has suggested, I guess im looking at a spring that rises in rate from 300lb/in too what?
If I was going to pull a number out of the air i would have said 600-750ish?
Sponsor
Full race on a 2wd we would use 475 to 550 rear and 570 to 650 on the front So realistically I would start with a 375 rear and a 450 to 475 front but if your ur planning on springing the konis in this way then you are going to over spring the shock so it will be a pointless exercise plus a waste of cash ! So like i have said buy better units but mate im in the same boat atm spent a few quid on a gearbox and turbo ect lol so having to wait for suspension but now at 34 psi on a billet t36 at full chat should be 420 is bhp the car feel dreadful and its been rebushed ect but the konis massively let it down
jessie_rs
11
03-06-2019 04:57 PM
155lee
14-09-2015 07:37 PM
track.focus'd
12-08-2015 05:53 PM
