help with 1600 crossflow scotland
hi all
looking for a bit help have a ford capri 1600 trike was running ok then started to splutter under full revs cleaned fuel filters but no better trying to locate carb help appreciated
mick
mick
I would say
Blocked fuel line
No gasket on carb
To much air in
Coil leaking oil ?
Points In distributor
Points in alternater or dirty
Spark plugs not set right
Also try a compression test
I have a 1300 in my daily drive ford Anglia and they are some of the problems I have had in the last month lol .might help also what's the magnet thing that's normally located next to the coil mine stuck .i have had all of these problems the most piss take thing was that I had everything changed and it turnt out to be a blocked fuel line and the at would cut out at high revs in top gear .now it's ok .
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
