Putting 2 Stroke in with Diesel
Old 14-02-2014, 03:01 PM
  #41
Colin_P
Colin_P's Avatar
The VOSA point Cossie Sean made is an important one!
As the two stroke will turn the fuel red, if VOSA dip your tank they will try and "Do" you for running red (tax exempt non road) diesel.
Best keep your bottles of two stroke in the car as evidence even if they are empty.
Still a risk though as I bet they won't believe you and seize your car, especially a 4x4 .
Old 14-02-2014, 03:54 PM
  #42
Bailes1992
Bailes1992's Avatar
I can't imagine 500ml of two stroke in a 70litre tank would turn it red?
Old 14-02-2014, 03:58 PM
  #43
j6kyt
j6kyt's Avatar
not all 2 stroke oil is red???
Old 14-02-2014, 04:03 PM
  #44
Bailes1992
Bailes1992's Avatar
Most of the cheap mineral oils are red. I've never had any issue with diesel turning red anyway.
Old 14-02-2014, 05:07 PM
  #45
theheap
theheap's Avatar
What good would it do if i use this on my 1.6 carb scrote? haha
Old 14-02-2014, 05:54 PM
  #46
slammedorion
slammedorion's Avatar
Its not a diesel you cabbage...
By all means chuck it in...
Old 14-02-2014, 06:07 PM
  #47
theheap
theheap's Avatar
Neither is my 50cc moped but it wont survive without it!
Old 14-02-2014, 07:00 PM
  #48
Matt Baxter
Back in black!
Matt Baxter's Avatar
I use it in my discovery along with veg oil makes the engine a bit smoother and a fair bit quieter!
Old 14-02-2014, 08:09 PM
  #49
studabear
studabear's Avatar
So its good for the injectors and pump really then?
Old 16-02-2014, 06:59 PM
  #50
rsturbolee
rsturbolee's Avatar
ive been using it for atleast 5 years in our cars and recovery trucks including my 2.4 transit mk7 recovery
its quieter smokes less less noisey better mgp on a run
I feel safer as its all lubricated, better burn means cleaner engine carbon build up etc, injectors will be cleaner so therefore not going out of programmed tolerance.
I put 300ml to a tank of diesel carlube redstuff I use, don't use the cheapy green,` if your car has a dpf use fully synthetic 2 stroke
Old 17-02-2014, 12:06 PM
  #51
320 bhp
320 bhp's Avatar
What would I put in a golf gt tdi sport on 58 plate and how much to tank full thanks
fordfiestamk3
11-09-2015 12:52 PM
atm
07-09-2015 05:39 PM
andrewmctiernan
Wheels and Tyres
03-09-2015 08:22 PM
Bighandsuk
02-09-2015 05:23 PM
Quick Reply: Putting 2 Stroke in with Diesel
