Pedal boxes
Old Dec 15, 2013 | 08:58 AM
Lee Reynolds's Avatar
Lee Reynolds
Default Pedal boxes
What are the brakes like when pedal boxes are used? With it being non servo assisted what is the pedal feel like etc? Depending on the route I go with the engine in my Mk1 I might have to fit a pedal box but know nothing about them.
cheers .
Old Dec 15, 2013 | 08:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
You just have to press a bit harder lol.
The one in my 3dr was fine. Good pedal feel etc. was a wilwood with evo 8 front brembos and focus rs discs front, evo 8 rear brembo and focus st170 front discs on the back.
Old Dec 15, 2013 | 09:01 PM
stu21t's Avatar
stu21t
I've got girling master cylinders with ap 4 pot 330mm up front and 300mm wilwoods on the rear and it works well. Stops instantly but you do need strong legs lol.
Old Dec 16, 2013 | 05:49 AM
Lee Reynolds
LOL I was kinda assuming you needed that bit more pressure lads What I meant was what is the pedal feel like for normal driving, does it make it a bit of a pig to drive with having to press harder. IE in busy traffic or say queing on a downhill slope and stuff like that? Anyone know about remote servo's?
Old Dec 16, 2013 | 10:20 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
Tbh i didnt notice that much difference. My car drove fine, and stopped fine.
Granted i didnt do a lot of town driving but pulling up from a ton was no bother.
Old Dec 16, 2013 | 10:19 PM
markk's Avatar
markk
If it has the right ratio and the right cylinder sizes then they req no more effort than a servo car.
Mine are very progressive.
Old Dec 17, 2013 | 05:47 PM
jamie956's Avatar
jamie956
Any idea of cylinder sizes when using std 2wd cos brakes I was thinking .750 front and .625 rear.
Old Dec 17, 2013 | 06:17 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Lol they are brilliant mate get my engines bought
Old Dec 17, 2013 | 08:47 PM
markk's Avatar
markk
0.700 front, 0.750 rear.
Old Dec 17, 2013 | 08:55 PM
jamie956's Avatar
jamie956
Interesting I would have thought it would have been the other way round, can you explain how it works I always thought the larger cylinders moved more fluid and the fronts being 4 pots would need more fluid over the single piston rears.
Old Dec 18, 2013 | 10:26 PM
Lee Reynolds
Baffles me
Old Dec 18, 2013 | 10:32 PM
markk's Avatar
markk
There are two things to consider when moving fluids, volume and pressure. You need to be able to move enough hydraulic fluid to actuate the cylinders, but, the bigger the cylinder the more you have to push it to get any pressure.
The smaller the cylinder the lower volume you move but the rate of effort becomes less, but the cylinder must be able to move the volume required at the pistons (calipers) otherwise you negate any advantage.
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
