Transit t350 75ps jumbo
I have owned the van for two weeks wen I got the van it started on the button for first 4 to 5 days as time went on it started to crank more times before starting so cleaned all lines and replaced filter bleed diesel lines and started to start a lot better drove 300 miles plus
Went out next morning and would not start at all just cranking and cranking put jump leads on after 10 mins of cranking and still nothing
So out came the easy start and with a very small wiff it started straight away
Runs perfect after and never seen a drop off smoke out off it
Van drive and runs perfect as coverd 500 miles plus once started with easy start but as soon a I turn it off it REFUSES to start just turns and turns PLEASE HELP
I thought the seal was the rubber in middle off filter u push on mate had inlet off tonite and back bolts were very loose replaced glow plugs checked wiring to glow plugs and fitted new relay and new gasket kit on inlet
van_dogg_pavvy
03-03-2016 09:30 AM
