Max boost for 9.5:1 comp.ratio
Evening all,
I'm working on a very simple turbo set-up on a bike for someone and I'm wondering what you would consider max boost for stock engine (apart from fuelsystem: that has bigger capacity pump, bigger injectors and rising rate fpr)?
The comp.ratio is 9.5:1
Opinions please
Opinions please
![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
as cossie sean has said, theres so much more to it than the comp ratio(that is part of it)
the ign map and octane rating of the fuel, the design of the piston crown, the piston/rod strength/structure, cam timing/duration etc
its all quite complicated, if its on mapable management then just up the boost a little at a time while mapping
7psi doesnt sound like a huge amount but i've see engines with det at less and engines running high comp running way m,ore boost so impossible to say
Lol enginemanagement is not mapable, it's a basic old EFI-system with 4 tb's, larger injectors and a rising rate fpr with upped pressure.
Rough, cheap and simple
Crank and rods will easily handle the strain but I'm more worried about the pistons or headgasket letting go...
The stock engine has 120 bhp, guy only wants around 150 or so...reckon 7 psi should do the trick...
B1mbo
As said there are so many variables.
I would say 7psi would be safe as long as you check the fuelling carefully. I follow the Honda scene a little and the standard 11:1 cr k20 they supercharge to 300 at 8 psi and turbo to a little more from 8-11psi but they are fully mappable.
Evening all,
Opinions please![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
Opinions please
And fueling is the easy bit, as it isnt difficult to make that safe even if it isnt optimal. Timing for the most part is the critical factor. So what control do you have over this ?
And timing you can make use of will depend on fuel, air temps etc etc. Detonation will be the killer of the engine long before boost or power itself.
It looks like it would be a crude option. But it would be feasible if that's all that is readily available.
I'm not in bike circles, so dont know what people would use or do, or what fits easily.
Hard to know at which point it's best just to install management that can be fully tuned properly though....which of course is the best option.
big floppy donkey dick
At 3000rpm and sparking after tdc on race fuel by any chance? ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Jimbo,
it was a 34mm IHI turbo/restricter`d WRC ***FMC Escos, on the P8 (Gems internal`d ECU)
the map was, "interesting" but Lindsay Shaw had a lot to do with that particular build, the cams and headwork were insane, HUGE lift....... so much that the head castings were tweeked so the cam lobes didnt foul!!
with regards to bike engines,
Harmonic ressonance is the biggest killer,
i.e "rod knock".....
they have very very shallow pistons for light weight and long rods for the high revs they produce,
think about pre-ignition, poor mapping at mid to high revs (again dependint purely on cam timing, fueling and ignition, think about this before buying anything mate)
Sean
Mark RS
12-10-2015 06:01 AM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
