Cosworth 4x4 gearbox oil
Hi I want to change the oil in my Saph 4x4s gearbox as the shift is terrible and when cold it can be reluctant to go in gear. I've heard motorsport developments sell an mt75 specific oil that is meant to improve shifting yet cope with higher bhp than the usual mineral mt75 oils from comma and carlube. I can't seem to find it on their website. Any help please?
Thanks
Thanks
Kroon oil SP 1031
Description
SP Gear 1031 is a red transmission oil, particularly developed for application in hand switched MT75 gears in various Ford models, such as Sierra, Mondeo, Transit and Escort. Adding special EP additives gives the following properties:
Description
- Optimal performance of the synchromesh: change gear smoothly
- Very good anti-corrosion and anti-wear capacities: optimal gear protection
- Good oxidation stability: longer life span
- Thin: a smooth change gear at lower temperatures as well
Resident Wrestling Legend
ford listed a specific oil for the mt75 but later they changed it to just normal stuff as it was the "same" mt75 as found in fwd cars, just with an X in the middle of it
the rwd/4wd mt75 box needs that specific oil while the later mtx75 boxes didn't
i can't remember what it was now either but the wrong fluid inside it makes the shifts shite
big_Rad
15-09-2017 09:36 AM
charliecosworth
19-08-2015 02:00 PM
