3dr spoiler problem
Old Mar 22, 2005 | 04:36 PM
B11GNS's Avatar
B11GNS
Default 3dr spoiler problem
the spoiler seems to be coming away from the tailgate and is a bit loose at this point obviously the spoiler will have to come off but what can i do to sort it out?
i know the pics a bit blurred but you get the idea.
Old Mar 22, 2005 | 04:39 PM
Toe Knee's Avatar
Toe Knee
Im guessing it came with some sort of self adhesive pads to stick it down?! Would have thought u could still get them. Failing that you can get double sided side moudling tape which should be strong enough or failing that something like stikoflex or tigerseal (silicon glue) would deff hold it no probs but would likely fuck the paint if it needed to come off after for any reason!!
Old Mar 22, 2005 | 04:40 PM
Rene's Avatar
Rene
had the same thing when i just bought it but ive managed to get some rivets in there with a thread so i can bolt it up properly
Old Mar 22, 2005 | 05:02 PM
righthooker's Avatar
righthooker
similar problem ,took the caps off and then tightend up the screws ,but they where somewhat threaded,could do with being re tapped i think
Old Mar 22, 2005 | 05:05 PM
B11GNS's Avatar
B11GNS
so it could just be the screws need tightening then?
Old Mar 22, 2005 | 05:09 PM
Rene's Avatar
Rene
cant even see the screw on top on yours!
Old Mar 22, 2005 | 05:23 PM
B11GNS's Avatar
B11GNS
i just took the cap off and found that the screw was a little loose, i tightened it but it made no difference. There seems to be a bracket of some sort that the screw screws into, could this be damaged and does anyone know how this bracket is attached to the tailgate?
Rene's Avatar
Rene
not sure tbh but as what i said above that's what i did
Old Mar 22, 2005 | 05:24 PM
JimRS's Avatar
JimRS
Chippys best mate.......GRIPFILL
Old Mar 22, 2005 | 05:25 PM
righthooker
no idea mate,maybe some one who dose boddy work or one of the breakers knows.I dont think they are accesable from inside the tailgait Same problem i have
Old Mar 22, 2005 | 05:58 PM
B11GNS's Avatar
B11GNS
Anyone else any ideas as it is an imaculate car and this spoils it a bit
Old Mar 22, 2005 | 06:05 PM
3drstretch's Avatar
3drstretch
There should be a bracket that is riveted to the tailgate B4 the spoiler is fitted then you screw to this.You can just make out the bottom bracket in your pic.And the bottom hole of the 3 is just a self tapper through the tailgate.It looks like your bracket is missing altogether.
Old Mar 22, 2005 | 06:09 PM
B11GNS's Avatar
B11GNS
it looks like it but the screw under the top cap tightens up tight so the screw must be tightening to the bracket
Old Mar 22, 2005 | 06:12 PM
SPADGE's Avatar
SPADGE
The bracket is probably loose underneath the spoiler so you have 2 options! Remove the spoiler and re-fit the bracket with new rivets or 'no nails' it
3drstretch's Avatar
3drstretch
Not really if someone has drilled the tailgate for a screw(Cos the bracket is missing).The tailgate is double skinned so could be tightening against the second skin rather than the spoiler if you get wot i mean.
Or as Spadge said the bracket may of come away from the tailgate so tightening the screw but to nothing.
Old Mar 22, 2005 | 06:17 PM
B11GNS's Avatar
B11GNS
Think i'll have to take it off and have a look, anyone know what size rivets are used?
Old Mar 22, 2005 | 06:19 PM
SPADGE's Avatar
SPADGE
Lol you might find the rivet has pulled through due to rust so just get a pop rivett set with a selection and keep the 'no nails' handy
Old Mar 22, 2005 | 06:23 PM
Lee Reynolds's Avatar
Lee Reynolds
or weld the hole up then re drill it.
Old Mar 22, 2005 | 06:24 PM
B11GNS's Avatar
B11GNS
it doesn't look rusty underneith (it is so far away from the tailgate that i can see there isn't ), do you know if you can still get the brackets from ford?
Old Mar 22, 2005 | 06:25 PM
SPADGE's Avatar
SPADGE
Not a chance
I'm sure it'll be ok though and the brackets are easy to make anyway
Old Mar 22, 2005 | 06:29 PM
Toe Knee's Avatar
Toe Knee
Whatever u do you want ideally to put a proper sealant there aswell, stops water getting in the rivet causing it to rust around it, common cause on most spoilers when their fitted without a sealant
Old Mar 22, 2005 | 06:30 PM
B11GNS's Avatar
B11GNS
Was sealant put on as standard on these?
Old Mar 22, 2005 | 06:39 PM
Ian M's Avatar
Ian M
dont use sealant because if water does manage to get in it wil sit under the spoiler and eventually rust the tailgate. apply cavity wax to the area under the spoiler which will protect it but wont hold water. the rivets are available from ford but tou either have no bracket there or it has pulled out and may require bigger diameter rivets.
Old Mar 22, 2005 | 06:49 PM
Ryan's Avatar
Ryan
bracket is either bent, or loose.
or riv-nuts have been pulled through.
all can be redone.
dirty-diesel
Oct 3, 2015 08:00 PM
S3an
Sep 26, 2015 11:39 PM
Vincereese
Sep 17, 2015 10:34 AM
S3an
13
Sep 13, 2015 10:01 AM
chris m1
Sep 7, 2015 08:02 PM
