Mondeo gearbox help, please!!!
Old Nov 21, 2013 | 04:54 PM
duderacing's Avatar
duderacing
Default Mondeo gearbox help, please!!!
The selector in the gearbox on my '55 tdci isn't engaging and doesn't feal like it is connected to anything.
I have an mtx75 from a mk2 1.8 petrol mondeo, and wondering if this will be a straight swap???
I'd guess the ratios will be different, but I'm more worried about starter, and other compatability issues.
The diesel still has a dmf.
Any help Pleas!!!
Old Nov 21, 2013 | 08:45 PM
GVK.'s Avatar
GVK.
Are the cables still connected?
If they are, remove the shift tower out of the box and check the bolt isn't snapped on the shaft.
Old Nov 21, 2013 | 09:04 PM
duderacing's Avatar
duderacing
That's what I suspect has happened, which will be a temp fix if I can swap it, but the housing is broken anyway (long story, but in essence, I bought a dog of a mondy!), so I want to replace the box.
Thanks for the response.
Old Nov 21, 2013 | 09:16 PM
GVK.'s Avatar
GVK.
Pretty sure the box from a mk2 won't fit, as you say..starter etc all different.
Old Nov 21, 2013 | 11:34 PM
vaughant's Avatar
vaughant
Most likely just the split pin in the linkage dropped out.easy enough fix plus you could just bolt a brand new selector on top of the box and be done with it.
Old Nov 22, 2013 | 09:49 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I've got a mk3 mondeo tdci MTX75 case if you want it, selector mechanism and bell housing pattern are different to the mk2
Old Nov 22, 2013 | 03:36 PM
duderacing's Avatar
duderacing
Cheers guys.
Just taken the selector mech off, and found the roll pin sheared, and as davey said, the mech on my mk2 box is different.
One of the rear mountings has been smashed and previous owner used some sort of resin to bodge it, so I think the best option is another box. From £30 locally on ebay, it's not worth the hassle of repairing the old one.
Cheers again for the input.
wowk
Mar 30, 2021 07:49 PM
mjonathan24
Oct 29, 2015 10:39 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
The Enigma
Sep 29, 2015 10:31 AM
