head unit help please
Old Nov 19, 2013 | 11:44 AM
will@greenlight's Avatar
will@greenlight
Default head unit help please
can someone please help me or give me advice re my head unit , its an eonon aftermarket sat nav thing , its in a focus rs mk2 , when im driving round town and slow down and come to junctions it just cuts of , same as if im sitting there listening to music it gets cold i put the heater on and again it will just turn of what the hell ?
Old Nov 19, 2013 | 11:49 AM
Oranoco's Avatar
Oranoco
Check for loose wires at the back but it may be a duff deck. Those Eonon units seem a bit too cheap to me.
Old Nov 19, 2013 | 12:19 PM
will@greenlight
yeah i think its the head unit aswell , ive had literally all the dash out checking the wires but everything looks good so annoying though
Old Nov 19, 2013 | 12:32 PM
pani_k's Avatar
pani_k
PassionFORD Member
Sounds like it could possibly be an earth or current supply issue. If you turn it right up does it flicker or cut out?
Old Nov 19, 2013 | 12:37 PM
will@greenlight
no it doesnt strangely , i spoke to an electrician about this he rekons these head units have a small cap in them and when that runs out it cuts of rather than taking power directly from supply it takes it from this
Old Nov 19, 2013 | 12:39 PM
salsheikh's Avatar
salsheikh
deffo sounds like a HU issue. i take it this didnt happen before with your previous HU?
i would try to install an extra earth wire too, just to make sure it isnt an earthing issue.
Old Nov 19, 2013 | 12:44 PM
will@greenlight
but im sure the wiring harness has an earth that goes to the main loom thats earthed
Old Nov 19, 2013 | 01:00 PM
pani_k's Avatar
pani_k
PassionFORD Member
You'd be surprised how much of a difference a proper earth makes to anything, especially where audio is concerned.
Old Nov 19, 2013 | 01:06 PM
salsheikh's Avatar
salsheikh
my car wouldnt even start cost one of four earth wires was slightly loose. rac man came out and tightened bolt and car started. i sat waiting for 3 hours dying for a pee and then had to just find a dark corner to do it...
Old Nov 19, 2013 | 01:14 PM
will@greenlight
i wouldnt even know where to begin changing the earth
Old Nov 19, 2013 | 01:17 PM
salsheikh's Avatar
salsheikh
just add a new cable and mate it to the earth cable from the head unit.
Old Nov 19, 2013 | 01:21 PM
will@greenlight
where to ground it though its all plastic crap behind it
Old Nov 19, 2013 | 01:25 PM
salsheikh's Avatar
salsheikh
remove one of the kick panels linked to the centre console and find a nice grounding point as its all metal underneath and run the wire up to the HU. you'll find it easier to drop the wire down and then attach it. i use 3 long cables ties taped together and tape wires to this to run it down into gaps.
Old Nov 19, 2013 | 01:28 PM
will@greenlight
what colour wire is it likely to be im assuming its black
Old Nov 19, 2013 | 01:55 PM
salsheikh's Avatar
salsheikh
racist, reported you
yep it should be a black wire. get one of these to test the wires first
http://www.justoffbase.co.uk/Screwdr...78-Draper-1169
ive added extra wire to mine as its never long enough!
Old Nov 19, 2013 | 05:29 PM
Rob Virgo's Avatar
Rob Virgo
are the plus 12v feeds reversed, two feeds are 12v switched high current for power and 12v low current switched for mem etc...
long shot but swapping wont do any harm bar losing station presets, worth trying ...
while the stereos out you could connect up a volt meter and try and recreate the turn off conditions to see if its power @12v is dipping???
Old Nov 20, 2013 | 09:06 AM
will@greenlight
il give that a go mate thanks , but wont be able to do it for a week its just went in to be wrapped
Old Nov 20, 2013 | 09:15 AM
RichieST's Avatar
RichieST
Friend of mine had an eonon sat nav unit in his transit that would do the exact same thing. Would also get very hot around the back of the unit where the heat sink is, almost too hot to touch. He junked it and put a pioneer unit in, had no problems after that!
Old Nov 20, 2013 | 11:45 AM
salsheikh's Avatar
salsheikh
if you can afford to get it wrapped then sell the eonon hu and get a decent one in! stops faffing around. mind you, i installed a pioner hu into my focus and it was a pita to get the cage to sit properly due to all the plastics behind the fascia.
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
