Mondeo/Focus blacktop difference
Zetec Turbo Baby Yeahhhh
![Question](https://passionford.com/forum/images/icons/icon5.gif)
Hello AGAIN!
Right, I'm starting to shit it a little bit now because i've bought a 2.0 '99 or '00 reg mondeo blacktop engine and have had work done to it in preperation for it to go into my focus mk1.
I know the gearbox will mount up but i'm thinking about all the other bits and pieces that bolt up to the block like power steering, a/c pumps, alternators etc. Will the mounting holes be the same on the block itself??
I've got a FRS crankcase if this has any bearing on anything?
Same engine last time I checked, iirc the only revisions was in the sump and oil pick pipe, mondeo back tops had a metal oil pick up with a diffrent shape sump (only a little different) and the focus had a plastic oil pick up but later changed back to a metal oil pick with no steading arm on it.
Thanks for the reply. And you're bang on abo it the oil pipe thing. I put on my sump earlier and it didn't fit. Luckily still had the focus one.
I don't know if you could help me out here, but I bought a yrs upper sump and noticed there is an additional threaded through-hole on the oil filter side. Not on my old sump... Can't quite work out what it's for??
ill ask one of the lads in the morning what its connected to for you.
Butbi don't think it's an oil return. The oil return is on the front of it already.
Buy a new tpye focus one iirc there only Ł15 and wont snap off if you hit the sump on something or like me snap the of when removing the sump lol, I couldn't really say as I havnt done on builds on rs blocks.
wowk
30-03-2021 07:49 PM
SMILER258
28-09-2015 09:04 AM
