GT25 downpipe to Turbo Gasket..
29-10-2013 | 06:13 PM
I thought with the compression from the v-band clamp on the FRS you didn't need a gasket, just checked fords and you do...?
Does everyone else use a gasket here?
29-10-2013 | 07:25 PM
l never have, its not the fire ring that's coming up is it?
30-10-2013 | 10:42 AM
It is listed as 'gasket' and shows it going between the turbo and downpipe..
30-10-2013 | 11:19 AM
[IMG]
[/IMG]
30-10-2013 | 11:28 AM
I'm using the fire ring gasket on mine.
30-10-2013 | 11:37 AM
Might wanna hide your vin/plate off that pic just in case
30-10-2013 | 11:43 AM
What is a fire ring gasket? Do you mean wire ring? and where does one go?
30-10-2013 | 11:48 AM
There is a recess on the downpipe, and the turbo
30-10-2013 | 11:52 AM
Ah i know where you mean, i thought that in itself would of been alright. Where did you get yours from? Looks like a trip to Frauds!
30-10-2013 | 12:56 PM
Fords. Not too dear really for what it is.
30-10-2013 | 01:03 PM
I guess not, although you want to see the prices on some other bits.
The heat shield - £129, or the oil return pipe £170, or maybe a small bracket for £372.
30-10-2013 | 01:23 PM
I used a generic gt25 return and a bit of flurolined hose to a brass stub that was tapped into the sump.
Sod fitting a head shield tho! You will prob end up with a tubular manifold at some point then just head wrap that.
30-10-2013 | 02:39 PM
Well I managed to get my hands on a FRS crankcase so I'll be able to whack it straight on. Just need to find someone selling a FRS return :/
Did you run water feeds to your turbo? Or not bother? ..
30-10-2013 | 05:10 PM
carpartexpress will get you the turbo ring/gasket
30-10-2013 | 05:38 PM
Quote:
Originally Posted by
JamboRS
Just checked that site, turns out it's cheaper at fords lol
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
