Sierra/granada
Fart of the Purniture
Shocks/springs are too tall - so they are no good, front shocks mount differently any way.
The diameter of the front shocks are the same as 4x4 Sierra/EScos. So you can use hub carrier and everything else if you wish, it would fit but it has a slightly wider track - so depends on arch rolling wheel/tyre choices.
There is so much more to know also.
Resident Wrestling Legend
on the fronts it's a bit more complicated as the tca's are longer and the hubs have a thicker shock diameter
the arb will bolt in (but gives slightly twitchy handling) as will the crossmember
the rack will also bolt in but there are conflicting reports as to weather or not you will have enough thread on it to wind the tre's in all the way or not
simple enough to tap some more threads onto the ends and/or chop some extra threads off the end of the rack though
depends on what exactly you want to swap over though, you can't use the suspension on either end though as the granada weighs about 400kgs more and the tougher suspension takes care of that
Rear beam was the main thing as its has the larger diff opening to suite the lsd's, also was going to fit either an 18mm or escos rear arb,
Fronts I heard that the 3dr setup handles better? Dunno if that's true?
It's more the fact that I'm fitting the boa and want everything to be able to handle the power as standard or TT, and I'm poly bushing everything so don't want to have to do it twice
The 3dr hubs give a higher front roll centre which gives more front end grip.
The Granada ARB will fit but is a bit wider than the sierras due to the longer tcas, but that won't affect the handling. It's only more difficult to mount it due to the extra compression that is needed to fit the tcas.
Oh ok so I take it the granada hubs are setup to fit 4x4 legs, as I've just got 2wd springs and shocks,
Has the granny rack got more lock that a sierra rack?
Do for do a 4 stud brake setup to suite the granny breaks as I'm either going for a sleeper look or standard cossie look so need the 4 stud hubs
Did you need to do any body bashing to fit you exhaust system as I'm looking to twin turbo it once its all fitted it and test drove it for a few months
Originally I used 4x4 rear flanges and Sierra 4x4 cos discs and on the front I stuck with the std Sierra legs and hubs with the granny calipers and 2wd cos discs. It all fitted with a very slight fettle to the front carriers. Subframes are identical but its easy to leave the complete engine and steering system connected to make easier when swapping. Imo mine understeered no worse than a std 2wd cos but recently I changed from the 29mm Granny arb to a 2wd saff version and its made a big difference. I think the weight of the engine is always going to make it understeer if you don't get the suspension right.
The wider track and more camber on the rear is caused by the rear arms. The plate that is welded to the arms where the hubs mount are a bit thicker on the Granada to give the wider track. They are also under a slightly different angle to give more camber, which is done because of the higher standard ride height of the Granada vs. the Sierra.
I have put the front Granada and Sierra arbs directly on top of each other and they are the exact same length on the Granada and Sierra, it's only that the Granada arb is a bit wider because the tcas are longer. But using a Granada arb on a Sierra will still put the tcas in the same location.
@Damo, I remember you saying in the past you had machined the Granada arb to move the tca a bit back so the wheels would sit more backwards in the wheelarch. I think that must have been because you are using Granada hubs instead of Sierra hubs. In the past I have also used a Granada arb with Granada tcas on a Sierra and it was fine. I even put a few washers in between the arb and tca to give more caster. Did you change the machined 29 mm Granada arb for a standard 28 mm Sierra arb? I assume this cured a bit of understeer? The thinner front arb will more front end grip and if it's not machined anymore it will give more caster which will also give more front end grip.
TBH I wouldn't use Granada front hubs on a Sierra. I have the feeling the put the wheels too much to the front and give a too low front roll centre, because of the higher standard ride height of the Granada vs. the Sierra.
The 3dr hubs would be best, but they are difficult to find/expensive. I thick the 4x4 cos front hubs would also give a good front setup when used with a 2wd crossmember and 2wd arb, but these hubs will push the brakes quite far outwards giving possible problems with wheel clearance.
Sorry to jump on this thread but need a bit of advice with a similar thing I want todo on my xr4i. I want to fit a 2wd saph front anti roll bar( will it move the wheels forward in the arch's) and will I see any benefit in fitting 2wd cossie front hubs and track control arms instead of the tankard xr4i items.suspension wise I'm running avo coil overs all round
2wd cossie front hubs come in 2 types, 3dr hubs that use tcas with a tapered hub fitment and sapph hus that use a tca with a pinch bolt hub fitment. The 3dr hubs give a higher front roll centre than the sapph hubs. Whether the sapph hubs give a higher roll centre than the standard Sierra hubs I'm not sure, but I imagine it's still better to have 2wd sapph hubs than standard Sierra hubs on a lowered car.
I fitted the Granada full rear in. Its got the LSD and the ARB is a thick one, cant remember the size.
Brakes are the same as a 4x4 cossie.
Yeh I know its a pain main reason I got the car so cheap is my m8 bought it originally just for the diff to put in his fiesta, so it came with no diff, so my aim it to fully paint and poly bush the granny rear end, so its all ready for when I get a diff
doga-ot
21-03-2015 07:41 PM
doga-ot
10-03-2013 06:17 PM
