Any one unseized an engine before
Old 13-10-2013 | 03:44 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Default Any one unseized an engine before
Just can back from trying to unseize an Aston Martin dbs engine that's bin sitting for 30+ yrs, and what fun I had lol, I tried everything I could and it still wouldn't budge?
Soaked the bores with wd40 for a couple of weeks then, diesel for a week, then went round to attack it, tried rocking it in gear, tried rocking the crank with a bar, tried putting pressure on the bar while hitting the centre of pulley, crack lock down the bores, using a torch and cooking the bores up, I even jacked up the bar while on the crank then first hit it with a hammer then tried engaging the start while the bar was under load, but nothing
So I've left it now with the jack under the bar on the crank bolt putting pressure on the engine and all the bores left filled up with wd40
Any more ideas welcome as we know worse case is to strip down and rebuild it but was hoping it would turn over as it was only rebuilt a yr before it got left
Old 13-10-2013 | 03:50 PM
T.E.D. Jordan's Avatar
T.E.D. Jordan
With all that done to it and it still not budging I'd think it would be madness not to strip it.
Jordan
Old 13-10-2013 | 03:57 PM
cabriolet's Avatar
cabriolet
get the wd 40 out fill the bores with cheap coke
Old 13-10-2013 | 03:59 PM
7sean7m7's Avatar
7sean7m7
Regardless if it was rebuilt a year before taken off the road, sitting for 30+ years is surely enough reason to strip it down?
Old 13-10-2013 | 04:00 PM
gingerturbo
Yeh I know, only 2 out of the 6 bores were holding fluid which points towards those bores being the problem,
Old 13-10-2013 | 04:03 PM
gingerturbo
Yeh I told the bloke before I touched anything be prepared for it to be stripped, so that may be the next option
Old 13-10-2013 | 04:06 PM
7sean7m7's Avatar
7sean7m7
Got any pictures?
Old 13-10-2013 | 04:10 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
What about heating some oil up on a camping stove an pouring it down the bore's?
I wouldnt just dump it in for obvs reasons but legend has it it really does work...
Old 13-10-2013 | 04:45 PM
gingerturbo
Got any pictures?
I have but it's being gay and won't let me upload them off my phone
Old 13-10-2013 | 04:49 PM
gingerturbo
That's a thought that and boiling hot water in the coolant system as its got liners
Old 13-10-2013 | 07:06 PM
dingla rs's Avatar
dingla rs
boiling oil works
Old 13-10-2013 | 07:07 PM
gingerturbo
Mmm sounds like the answer
Old 13-10-2013 | 07:10 PM
vaughant's Avatar
vaughant
Out of interest have you tried removing all aux belts etc? If there's anything like that seized again you can try what you like and have no joy.
Old 13-10-2013 | 07:11 PM
Fraggle...'s Avatar
Fraggle...
On a tangent
I have done it before, once on an old rotivator, on a MK1 fez crossflow, and a c1j mill.
Trust me it did work, although at 30yrs your on an uphill
As for boiling water yes but drain all old out first, DONT use any antifreeze, and again gently does it!!!!!
Good luck fella, let us know the outcome, love to see some pics of the aston
Old 13-10-2013 | 07:15 PM
ROBnoTOP's Avatar
ROBnoTOP
Lost for life.....
Drill out a sparkplug or make adapter to fit the plug thread, with an grease nipple on top.
Pump grease in the cylinder with gun, make sure the valve´s are closed.
It did work for me anyway....
Old 13-10-2013 | 07:17 PM
gingerturbo
Yeh I had to as the viscous fan got in the way of the big bar, plus the water pump is seized, when the belts came of they were moulded in the shape of a triangle lol
Old 13-10-2013 | 07:20 PM
gingerturbo
Can't as that would mean removing the top end/cams and as said if I'm going that far might aswell strip it all down, I'm treading as thin as possible as its still bolted together and not looking forward to stripping a chain driven Aston straight 6
Old 13-10-2013 | 07:23 PM
ROBnoTOP's Avatar
ROBnoTOP
Lost for life.....
I understand ..... hope you get it sorted !
Old 13-10-2013 | 07:25 PM
gingerturbo
Engine bay
Old 13-10-2013 | 07:26 PM
gingerturbo
Cheers m8
Fil's Avatar
Fil
ELASTIC BAND
surely if its that siezed and you unseize it with that amount of effort, then your going to do some damage .
so why not just save a potential expense and pull the engine appart.
butter than a snaped crank, bent rod etc.
Old 13-10-2013 | 07:32 PM
gingerturbo
Good point the only downside is where the car is the house is prematurely sold so it needs moving
Another pic
Old 13-10-2013 | 07:34 PM
gingerturbo
Another pic anyone shed any light onto the name? Is that the hand builder?
Old 13-10-2013 | 07:36 PM
gingerturbo
Another one
Old 13-10-2013 | 07:37 PM
gingerturbo
Last pic till I go back
Old 13-10-2013 | 08:10 PM
bigchez's Avatar
bigchez
Are you joking? You think it's any co-incidence astons to this day are called DB7, DB9, DBS.......
Good luck with the engine.
Old 13-10-2013 | 08:11 PM
GVK.'s Avatar
GVK.
David Brown was the former owner of Aston, hence the DB in the model names of the cars.
http://en.wikipedia.org/wiki/David_Brown_(entrepreneur)
Originally Posted by Wikipedia
In 1947, Brown saw a classified advertisement in The Times, offering for sale a High Class Motor Business. Brown acquired Aston Martin for Ł20,500 and, in the following year, Lagonda for Ł52,500, followed by the coachbuilder Tickford in 1955. He subsequently concentrated all the Aston Martin manufacturing at the Tickford premises in Newport Pagnell.
The legendary 'DB' series of Aston Martin cars, including the Atom, the DB2, the DB3, the DB4, the DB5 (famously driven by fictional character James Bond), the DB6, the DB7, DB9 and the DBS were named after Brown using his initials. Ironically, while at the helm of Aston Martin, he actually used a rival product, a Jaguar XJ Series I, as personal transport. Aston Martin was sold off in the 1970s when the company was in financial difficulties.
edit - late reply!
Old 13-10-2013 | 09:08 PM
studabear's Avatar
studabear
Some none sensible approaches from me.
1. Ring Edd China.
2. Tow rope, 4x4, drop the clutch of the Aston at high speed.
3. I will stop the stupidity now.
Would be good to see how you get on with this, best of luck to you.
Old 14-10-2013 | 03:17 AM
brad's Avatar
brad
No matter what you do it'll need stripping down!
The rings will be fucked, the bores are likely to have 30 years of crap up them most of the seals will have perished and pretty much every moving part will need at the very minimum stripping off and lubricating.
What are you hoping to achieve by unsiezing it in situ? surely your not thinking of trying to run it?
Old 14-10-2013 | 04:06 AM
Acidburn's Avatar
Acidburn
whats happening with the car when its removed from the garage, has it been sold and how did you find it.
Sounds like a good barn/garage find and hopefully gets sorted out, keep with the updates mate
Old 14-10-2013 | 04:56 AM
JK99's Avatar
JK99
For all the time you'll spend pissin about trying to unseize it you could have pulled the engine out and stripped it by now.
Isn't there a possibility of doing some terminal damage to the block etc by trying to free it off after all this effort?
Old 14-10-2013 | 07:14 AM
gingerturbo
I know fuck all about Aston martins lol
Old 14-10-2013 | 07:21 AM
gingerturbo
The bloke knows worse case,
I was expecting to break a ring but it was really seized so it may be a strip time,
I wanted to get it turning so when it does get stripped I know I can get it to TDC and mark it up, as I know nothing about Astons and getting knowledge is going to be impossible
Old 14-10-2013 | 07:22 AM
gingerturbo
The blokes dad had it from nearly new then had kids and left it in a garage for yrs, so the idea is to try and get it back on the road
Old 14-10-2013 | 07:24 AM
gingerturbo
Possibly but as its got liners being an alley block I'd rather unseize together so it doesn't disturb the liners
Old 14-10-2013 | 07:36 AM
Trist's Avatar
Trist
Wouldn't keep putting time and money in to be honest. Strip it. You can be trying for another week. And possibly still no luck. Or this time next week it could be sat across a bench all cleaned up in bits.
Plus if the rings are stuck on the bores it's going to leave a lip or mark. If you do get it moving the rings are going to scrape past the mark and just do damage.
Old 14-10-2013 | 10:06 AM
T.E.D. Jordan
I forgot about the boiling oil trick, that can work.
Jordan
Old 14-10-2013 | 10:16 AM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
try this nothing better
http://www.kanolabs.com/
Old 14-10-2013 | 03:51 PM
gingerturbo
Fuck I forgot about that shit they use that on the old boats when restoring them
Old 14-10-2013 | 07:49 PM
theheap's Avatar
theheap
^^^ that any good for running a cvh lol
Quick Reply: Any one unseized an engine before
