Bosch injectors help
Fleet Manager
Right I need to change the standard blue injectors in my fiesta rst set up
The Common upgrade is cosworth baiges
But I have read that cosworth yellows will also work
This got me thinking and looking at other injectors from the cosworth set up and I found a few just wanted to know the differences between
Baiges
Yellows
Blues
Greens
Grays
Light Blues
Wondering if I could use anything else with a standard rs cvh internals and a T3 as baiges seem to be the oldest and most expensive
Baiges
Yellows
Blues
Greens
Grays
Light Blues
Fleet Manager
I'm also not going to go down the standard ofac route I'm going to use a boostmonkeys/mega squirt ecu I already have -31 and it's been set up to 1bar
Because burton know nothing about ofab
Cosworth injectors are wrong impendence and biege are not from cossies
P.s if your going ofam you don't want any of these injectors, they are old hat
Go Siemens dekas or astra vxr injectors
Dekas can be had for £200 new
And vxr injectors are £75 and can flow 350bhp on a zt but are a great budget injector which I'm using for my ofam
cant you just run a different resistor etc, not to hot on the early Fords but i run the new slim Bosch motorsport 1000cc injectors on the Evo and just had to mod the standard resistor pack for them to work correctly
Fleet Manager
So baiges aren't from a cossie then?
Guess The confusions come from people selling them as standard cosworth injector?
Or the fact that a 195 chip changes the resistance?
Much rather use the newer vxr injectors do these fit directly into the webber fuel rail???? What should I look for just z20let injectors?
Just for clarification I'm using a 1600 Cvh on OFAC
mk3ste
17-10-2021 10:09 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
