Help with transit throttle
Old Oct 9, 2013 | 07:51 PM
spot1's Avatar
spot1
Default Help with transit throttle
Hi Folks,sorry this isn't very exciting but i have a fault on my 55plate 280swb transit that is driving me mad.For the past 6 months every now and then the throttle would stick at around 1500-2000 revs turn off ignition and all was ok,this got worse until i put a brand new ford pedal on 3 weeks ago all fixed until tonight.Now it is sticking again but a quick tap on the pedal seems to fix it this time so is this new pedal faulty or should i look elsewhere
Cheers Spot
Old Oct 10, 2013 | 05:45 PM
focusv8's Avatar
focusv8
Had a similar thing on a Peugeot van.
Was the coolant temp sensor failing, engine was going to high idle thinking it was cold.
Old Oct 10, 2013 | 07:23 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
you need to take some live readings mate, no good guessing really.
pedal voltage should be 0-100% and the correct voltage rising at the same time
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
