Been on the paint again lol
Had a customers car that someone took a dislike too, she asked me to try and tidy it up a little for her,
Not normally the sort of thing I take on due to time, but I managed to take it in over a few days between other things
The damage very deep and rusted
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/d9ee40dfa75fea8626752bb3309e0599_zps89bdc84b.jpg)
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/da79d543a748a66ed0ba1241856a0120_zpsd002eca7.jpg)
Knocked it back to bare metal and feathered the repair area before etch and then priming the area, then blocked it back
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/7231495353fcde5e2e99cb9c09c07cbb_zps3b751dd0.jpg)
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/6df7c572cb21ec09c6ed731cba7ba10d_zpscce73ff9.jpg)
Then prepped up and gave it a nice colour coat and hit it with 4 coats of lacquer before a 1200 wet and dry block and machine polish
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/566acce4cca2ebb30617ddb092ae1141_zps54249c2a.jpg)
Not a bad finish from a rattle can!
Mission accomplished
![](http://i58.photobucket.com/albums/g280/JTECHSAFF/532ac0706604515746d1aecea36de36e_zps6f47229d.jpg)
It's not bad, I was able to fade the colour towards the leading edge of the front door as the damage was quite far back so there is hardly any colour difference there,
The rear door had damage right to the edge so I wasn't able to do this on that door, the customer didn't want the expense of blending into the quarter but luckily the paint was a very good match so it came out well in the end.
Very good job! Its surprising how good a result you can get with a rattle can with good prep work and some care taken.
you cant fix stupid
i did a repair on my silver focus rear quarter and was over the moon with the results. but then i spilt some petrol on it at the track and the laquer was ruined. gutted but think rattle can laquer is crap. any tips or suggestions on best laquer to use to prevent this?
great job by the way
Will look fine, I've done quite a few including a load on stus M5,well over a year ago, looks no different to the day I did it, as long as the prep is good so you get no shrinkage it will be just fine
well done,silver and goldish paints are an arse to blend in,people not painting often gets amazed when they look into a can of silver and they see the black circles as you stir around in it,so easy to get that faded edges,so well done :tup:
Yes you are right, you do get what you pay for, looks like a nice job you done there. Did that take much polishing? Have just seen soooooo many aerosol craze up or fade after time, and like someone has just said if you use a 1k lacquer then hard chemicals can ruin it.
I have always blocked and polished anything I've done just to de nib and cut any orange peel off so its dead flat.
I ran my own body shop for years but got fed up with it, now I kind of miss it
Belting job from a can
, I did a mate's 306 estate a while back, rear bumper and tailgate...
The flat and polish really helps...
I always find the clear rattle cans never have wide enough coverage for a big panel...
It's do-able but now I'm using my guns and compressor, it's hard to go back to cans...
Also did a 206 rear bumper and front grill in cans which was spot on... As you said its the prep that makes the difference...
![](https://passionford.com/forum/images/smilies/roi.gif)
you cant fix stupid
if i flat it back with 1500 or 2000 then use a 2k would that be ok? iv seen some cans on ebay in 2k. my local paint shop said they couldnt get 2k at the time in rattle so thats why i didnt use it but never knew that petrol would ruin it
you cant fix stupid
thanks for replies and sorry for thread hi jack
you cant fix stupid
any proper dealer that offers cans and mixes the paint for you can do it in 2k,they mix it with hardener before pressing the botttles,the bottle life is around 4-7 days depending on temp in shop or so,nothing for full fender jobs but i use it for repairing fenderflares and stuff for solid paint cars and when doing small stuff like calipers and shocks and stuff it can be alot easier than doing it with gun and the hassle of cleaning (metallic is allways 1K to be clear,pun intended
) the ratio for most common paints are 2:1:0,15% ,2parts paint,1 part hardener and 0.15% solvent,and most cans out there has that allready in them so shop only needs to make the paint/hardener mix.
and just to add to it,always use mask,even hardened putty gives of iisocyanate fumes when sanded,the dust is bad,fumes are worse,if you lay a cottonball the size of a golfball in your hand and drop a few drops of thinner on it it takes a few mins then you can read it through your breat with a breathaliser so it's not nice stuff
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
