Underside Resto Help and Advice
Ok so Im thinking of doing the underside of my car this year, not to concorse just clean it up (preventative maintenance) im a bit daunted by the thought so I thought id ask on here for hits and tips
also id just be using axle stands so taller the better, what do you lads use?
and can you get white underseal?
Also pics would be nice
Also pics would be nice![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
im hoping to take it rite back to bare metal then prohaps galvanise then underseal over that.
I also want to do all the running gear and new bushes
Yeah we took it all off with wire wheel on a grinder. I did mine on my back and we got a spit for my brothers. We striped them to bear metal then zinc primed, seem sealed, zinc primed again, stone chipped, 2k primed it then paint. All the axles and hubs and things was sent to the powder coater's then it's just a case of new bushes, cv boots pipes and bearing, thinks like that but that's the good part putting all new parts on
Mine took ages, biggest mistake not having everything there to just bolt on, you need new bearings, pipes basically everything as you see one bit clean so you have to match it, I steam cleaned the underside to remove old wax, then wire wheel - belt sand every seem and around every hole then rust treat then what ever coat you desire, I went for black spray wax as black car but any other colour it would have been painted
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
