Another gear linkage thread
Old Aug 21, 2013 | 06:52 AM
Fordmad!'s Avatar
Fordmad!
Default Another gear linkage thread
Getting my 3i back next week and after reading all the threads i understand that upgrading to a puma linkage is much better
Does anyone have any tips, is it easy to do?
Is it defiantly worth doing?
Any help would be appreciated
Old Aug 21, 2013 | 01:29 PM
swiftyrs's Avatar
swiftyrs
easy job , av done this upgrade on my s1 , took bout 2hrs start 2 finish , u will need 2 drill 2 holes 2 mount the rubber holder of the puma linkage on the shell, and trim the width down also 2 fit in the shell's tunnel , apart from that it was a doddle ....gear selection is now similar 2 a quick shift as the throw is a lot less than standard linkage ....
Old Aug 21, 2013 | 01:43 PM
Fordmad!'s Avatar
Fordmad!
Do you loose neutral??
What gear do you select when you swap the linkages reverse or 4th?
Old Aug 21, 2013 | 02:12 PM
Paul_RS's Avatar
Paul_RS
If you set it right you shouldn't loose any gears?
Old Aug 21, 2013 | 02:41 PM
Fordmad!'s Avatar
Fordmad!
I seen some where that converting to the puma linkage you dont have a neatral gear?
Old Aug 21, 2013 | 02:57 PM
bluescortcossie's Avatar
bluescortcossie
as a further upgrade you can replace the rubber bushes on the lever and rods with solid bearings , this will remove any movement but you will get a bit of vibration through the lever
any bearing specialist will have something that will fit
Old Aug 21, 2013 | 03:05 PM
Fordmad!'s Avatar
Fordmad!
To be honest my linkage is in very good condition i just heard that its an upgrade worth doing
Old Aug 22, 2013 | 06:54 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Done it before too and never lost neutral? Deffo a worthwhile job!
Old Aug 22, 2013 | 06:59 AM
Fordmad!'s Avatar
Fordmad!
Righto i'll give it a go
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
