355mm in 17" ?
Anyone fit a 355mm brake discs in a 17" wheels ? What model of wheel and what et ?
I Have a 355mm discs with a brembo 8 pots calipers from a wrc front and rear the brembo 4 pots in 330mm , now i have a 18" cromodoras in my sapp , the problem is the 18" for sapp only fit 215/35/18" or 225/35/18" and in this sizes i cant find a good wheel , only a Bridgestone S001, but i want check any semislick or slick for track events, and i need go to 17" to fit in the sapp r888 or similar tyres.
Best Regards.
Best Regards.
The 60ft Launch King
If you get the arches rolled you'll fit a 18x8 with a 225 tyre not a problem. I've had mine done and could fit 18's not a problem (my 17's are 8" wide)
Then your 355m will fit under without a problem![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Would LOVE 355/378mm 6/8 pots on mine, but finding mk1 RL7's in 18's are like finding rocking horse shit unfortuntely
i have about 15mm clearance from the spokes to the caliper these are the AP CP 5555 which these calipers can take a minimum 356mm x 36mm disc to a max 380mm x 36mm discs
The AP 6 Pot 7040's (smaller pistons also) take a min of 330mm discs to a max 356mm
my wheels are 8x 17" et 25 allround
that is very old pic ,,,,,,,that Rl7 is an 8 x 17 et 35 i had about 5mm clearance
My calipers is a brembo 8pots from wrc car... I need check with some wheels!
1st to 200 without NOS
Juan, an 8x17 Compomotive wheel should take those brakes.
Best Regards.
1374lee
03-10-2011 08:05 AM
