View Poll Results: CVH EFI or MFI head?
Voters: 19. You may not vote on this poll
CVH - EFi Head compared with MFi head
I have my own opinions and my own reason's for choice.
After reading this topic i thought i would ask everyones else's opinion
https://passionford.com/forum/viewtopic.php?t=109182
Whats better for porting, polishing, bigger valves, etc...
Is there any difference? Or is it just whats prefered?
Please leave a reason for your choice.
i was under the impresion that the mfi has bigger valves??? av got an mfi head runnin with a carb on my escort. obviously theres differences inlet side with the injectors and manifolds bein different.
stumped
stumped
I know the EFi head has the notches on the inlet for the injectors but beyond that I'm stumped. That was the only real difference I noticed when I put a new head on the 2i. Didn't pay any attention to the valves though TBH
Wouldn't have though there was that much in it. Saying that a few years ago the EFi lean burn head was considered an arse to tweek. So there must be differences there
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
just finding my feet
Originally Posted by pauldudley
hi ya jano I was told by a man in burtons that the mfi head gave 10bhp more power when they tested it.
was both heads of the same capacity or not ???
as burtons know there stuff and all that but how many different heads did they test and was it on the same engine ect or different cars
did they swop em back over and see if it was still the same too
well as far as I know there put early head It mite have been xr3 carb "is there any differance?" one on A s2 and it on rollers and 10bhp more and I think there both standard
yeah but after a certain lift they just flow the same air, infact the efi ones have a better flow design going by that, looks less turbulant, but then my stage 3 head had bigger valves to flow more air,
are they any bigger in diamiter ???
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
on my xr2i big valve head valves are 43.5mm inlet 38.5mm exhaust, an its all ported had valve throats shaved n stuff
ive got an old erst head stuck in the ocrner here and thats got some nasty looking bends in the inlet where mines all smooth
think if ya look into it abit more ya will see what i mean
theres only son far a valve needs to be open before theres no more air that can flow !!!
the shape of the valve being like that will flow moew when opeing it but will make the air sweep, not hit and turn
theres alot to head porting that im looking into and i do thank jano for mentioning the difference between the valves as thats a good thing hes discovered
now im sure if ya gonna re cut the valves ya would fit larger ones but then im sure jano aint gonna give too much away
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
cause not everyone wants to use just one engine, may aswell say why not slap a vtec engine in it, sounds better and revs the tits real nice, no need to fook about with turbos
then theres the others who swear by bike engines, there smaller, cheeper and more fun, why bother with 16v heads
then theres the thought of why not stick a v8 engine in it, cheaper than a crack head whore dying for a fix and hits peak torque lower in the rev range
think its all due to one thing
thats the engine spec ya wanna go !!!!!!, if ya want a xetec engine fit one, if ya want a CVH fit one, if ya want a hampster in ya engine bay fit one, if we all used the " fit a ==== engine" then we would all have the same power outputs
oh and different engines respond differently too
hope that helps
hope that helps
yeah ive just converted a mfi head to efi and after precision measuring ect ive actually made it better than a efio head as the efi fuel pattern hits a wall rather than flutes in the head
i could be talking bollocks but i will know for sure if its worked
Custom
