2 litre pinto misfire
#42
insane
never had points electronic ignition with module didn't work ,thats why i have got power spark dizzy ,soon know if its faulty when garage has it on friday fingers crossed they sort it ,been off road to long lol
#49
As good excuse as any now for an XE transplant, or a YB.
#50
insane
I had same problem lately on similar engine 2litre 205 pinto ported 285 cam, 38dgas, K&N 4 branch
Turned out to be the cheap ebay electronic distributor kit replaced it with a modified aldon distributor and bosch coil runs grand now
#56
hmm i cant understand your not too happy with all those new parts , but it can only really be the coil , even though its new it can still not be working as it should be (my brother had a problem with a new genuine makers coil put an old one on and it ran fine ) so may be worth trying to get hold of one or a lend of one to try it rather than buying more parts , on my pinto i have a group a cosworth coil on it
#57
also with the jetting i am guessing that they have sent it to you on a base jetting set up ie would need set up after fitting for your spec
#58
insane
yeah m8 needs setting up tried 2 other coils the same thing is it did exactly the same thing with old dizzy and coil modulator leads and bike carbs and regulator thats i reckon it could be a valve problem everything i have changed doesn't alter the way the car runs
chowfornow
14
05-01-2019 09:01 PM
