rolling roads how to tell wich is more spot on with bhp
how spot on is engine advantges rolling roads as my car was ther 2 month ago and made 354 bhp and it was ther last year and it made 354 to it was spot on but went in to prism motorsport rolling road and my car made280 who do i belive
Location: *PF TERRORISTS CARTEL* Bin flocking Youngens :cry:
sounds about right.
need to take my car there, would deffo be 500bhp
Spadges car made 485bhp on greys when the limit on greys is 440bhp max
what spec is your car???
it was run in 4th gear he done 4 runs and it was fly wheel power iam running greens 4x4 cooler t34 turbo full stainlees exshust 004 fuel pump 3 bar map motorsport leads and plugs chip ap racing clutch group a head gasket full engine rebuild group a coil runnig 21 psi 1.5 bar holding 1.4 its a stage 3 conversion should 330 bhp conversion but it made 354 ant EA and was over the mooon but whent to prism motor sport that has just had a rolling road fitted so may be its that i dont now but he did say every one wasnt happy when they came for a powere run ther after coming from power engnering to his place so surely his machine is worng
Best dynos I have ever seen are the chassis dynos. You take the front wheels off, bolt and adaptor plate in place and hook the hubs upto a dyno.
Get no loss through using traditional rollers and are so accurate they can show the power drop from an engine when you turn the headlamps on.
I just wish I knew a place that had one other than my old college.
rapidcossie, but thats the normal package deal you get on a stage 3 saff green 3 bar chip t34 ect ect and have seen lots off cossy get 330+ bhp ive put my car up with other cars runnig 345 bhp and have hade no problem pulling away a littel bit
Mine made 365bhp on greens at EA & my friends made 378bhp still on greens at EA, don't really care if its right or wrong because it drives & pulls well
Simon.
Simon.
mine made 374.9 at EA, it has been on 2 other r/roads and was within 5 bhp either way (its on greys)
its a a bit more than stge 3 and if anything was lower than expected
Paul ran it in 4th and he got me about 25 bhp from fettling with the map
bottom line is , it doesn't matter what bhp it makes...its all bollox anyway, a rolling road is just a tool to aid setting up and/or modification proving, it gives you a base figure that you can work from..........its like stu from msd doesn't use a rolling road, he does his on the road using the seat of his pants/feel to know when its running right, i bet you can never pin him down to guess a bhp figure either!! and that will be for the simple fact the next rolling road you go on if it is 50 bhp down from what he quoted, you would say either he or the r/road is wrong
It does not matter if it makes a zillion fookin horsepower, its how it goes when your driving it.!
I run my inlet cam quite early so it gives me an on off switch power delivery at about 4500rpm and it feels lightening quick, some others run there cams late so the power comes in smoother and later, neither is making more power but i bet you would say mine is quicker/more horsepower (albeit a fooker to drive) but i would get my arse whooped on a trackday if i left it the way it is
Stop worrying about figures on paper and get the car set up to your wants
People get caught up in this must have xxxbhp crap........300 hp in a 20 year old road car is loads mate......most people do not have the ability to use 300bhp to its full potential anyway..........!
if you use a tuner and are happy with his work, forget about bhp figures , just look at the increases they are giving you, if you go in and it makes 380bhp on his road and by the time it comes out makes 450bhp..........just remember he has given you a 70hp increase and not a 450bhp engine...and be happy with it
Pugo
Pugo
thats a hud dyno,,, a chassis dyno is what we all call rolling road
Posted: Sun Mar 20, 2005 1:50 am Post subject:
"a rolling road is just a tool to aid setting up and/or modification proving, it gives you a base figure that you can work from."
Testing the future
its like Stu from MSD doesn't use a rolling road, he does his on the road using the seat of his pants/feel to know when its running right,
the accelerometer is as good as any dyno at telling you if you have gained power (or torque actually), as long as it's used under the same conditions (same piece of road, same wind direction, same vehicle weight, same ambient temperature, same tyre pressure etc, etc.)
as gareth is telling you, a rolling road can be accurate at measuring torque at the wheels, and both readings that you have could be correct (if yoyu take the at wheel torque figure that they should've given you). it could be something as simple as the airflow thru your i/c was not sufficient at prism, giving a high ACT which will give lower power. without comparing like for like, with all the parameters involved, you cannot say if one is right or wrong.
i would like to say to every one that has replyed on her a very big thanks to all . i will forget about bhp and numbers but i have a problem with my car .. her goes i put my foot down and the turbo spools up very nice and when iam flat out it seems to tug in and and feel slugish but you just here it like as if it just whants to burts in to revs but it dont was told that my leads have to much resistance and are showing fault on the rolling road. ther the 909 motor sport leads ther no good but can that cause it to feel slow. it boost up 1.5 bar holds 1.4 so boost looks ok but it sound like it being strungeld thats what it sounds like so please help me out
I watched a webber carb specialist set up a pair of 45's once (after a crypton tuner had got his hands on them) the tuner said he never trusted a meter he just listened to the engine.............and fook me the car flew afterwards
Pugo
as for accuracy on rolling roads, there are so many variables, i find it difficult to believe that going from one to another you will get the same readings.........
Pugo
like as if it just whants to burts in to revs but i dont
went back to the rolling road were i hade my car on a powere run only to find that ther machine was out by 30 bhp so iam happy agine but i still have a holding back problem
abdr500, it could be a number of things, and I bet when you discover what it is it'll suddenly seem simple - it always does, but I'd hate to leave a list and you replace the items and it still not be right
Some tuner advice/diagnosis (hard with something like this though over the internet, if you can I'd recommend taking it somewhere) could save you money in the long run, with most of the sensors on a cossie engine costing 20-25 a pop, it could soon add up.
Sorry the leads didn't fix the issue, but that's what it was on my old Sapph - verified on a RR with Crypton tuner attached to the leads, which I'd hope is how the RR you used diagnosed the leads as breaking down.
Does the car do it at any particular rev's or are there any other symptoms at all, smoke, rev counter bouncing around etc??
all it does is feel like as if i am down on boost by alot but my gauge says iam alright its like runnig std boost on a stage 3 sapp but boost is not down it goes to pull well and it does for about a second and then just feels flat dying not going fast up into the rev range but gets to 7 000 rpm eventually but no sighn off smoke at all the car feels like ther obstruction and goes into retard mode iam thinking igntion problem
Caraholic
Sounds you have a loose keyway and it's allowing the cam timing to swing, which would explain why it feels as flat as a fart. This is quite serious and needs to be sorted sooner rather than later. You need to take it somewhere that knows Cossies inside out (such as Harvey at SCS 01733 576 614) for a proper diagnosis though.
