Help need ASAP cosworth tps pf01
Having idle / throttle issues .
And realised my l6 is running a pf09
I have a pf01 to put on but when I take readings I'm getting
0.35 closed throttle
4.8 volts as soon as I touch move throttle
0.2 fully open.
Is this correct ?? As I've read numerous times it should have 5v Or as close to on closed throttle???
Copied this from another thread and its exactly what I'm getting
0.2 fully open.
Have you swapped the two outer wires? The pf09 and pf01 have opposite polarity so the wiring will have been swapped to use a pf09 on L6, you will need to swap it back.
The pf01 will go open circuit at idle, this is the main difference between the two sensors as the pf09 does not and this will cause idle issues as with a pf09 on L6 the Ecu is never aware the throttle is closed.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
Adam Graham
06-09-2015 06:04 AM
