focus st 05 crankcase oil vent separator
Hi all can any one help. Just replaced the crankcase oil pipe as was split and causing a high pitched whistle. But after I finished its no better. Seen there can be a diaphragm loose in the separator itself. Is this easy to replace at home and how???
http://www.carpartsexpress.co.uk/pro...hStartRecord=1
oil filter housing, half way down the page.
once you get the airbox out the way iys only 4 10mm bolts to remove and a couple of 8mm ones,pretty easy job for the home mechanic
