Brake help needed - it's buggered!!
Old Mar 17, 2005 | 07:28 PM
James Raby's Avatar
James Raby
Default Brake help needed - it's buggered!!
Car went down local garage today to get the brake system bled with new stuff
Now, I've got it back and its 100 times worse
Brake pedal nearly goes to floor and no bits at all
Need exact procedure how to bleed AP-4 pot calipers with a rear disc conversion
Please help and there's got to be something they haven't done or something has broke
Also, the servo tilts forward at the top when brake pedal is pressed, moves about 1/2 inch!!
Old Mar 17, 2005 | 07:32 PM
kjc300's Avatar
kjc300
are the calipers at the top a la 4x4 cossie???? if so you need to bleed them upright, so you'd need to undo the calipers and sort of support them on the disc (so the bleed nipple is uppermost) - then bleed it in that position!!
Old Mar 17, 2005 | 07:40 PM
James Raby's Avatar
James Raby
Kev, haven't a clue what you mean so went out and took a pic for ya LOL
Old Mar 17, 2005 | 07:47 PM
James Raby's Avatar
James Raby
Or, you taking about rear discs?
If so I think I know what you mean now...
Old Mar 17, 2005 | 07:52 PM
James Raby's Avatar
James Raby
Just claify though if ya can please... Might of mis-understood
Old Mar 17, 2005 | 08:11 PM
TrickyDicky's Avatar
TrickyDicky
Default Re: Brake help needed - it's buggered!!
if the servo is moving on its mountings that would increase pedal travel!!
Old Mar 17, 2005 | 08:21 PM
James Raby's Avatar
James Raby
was fine b4 fluid change though, btw u have a PM
Old Mar 17, 2005 | 08:25 PM
pau1rs's Avatar
pau1rs
when i bled my wilwoods and cozzie rear discs the pedal was crap.. but just using them brought the pedal right up and they are fine now!!!
maybe i was just lucky!!!
Old Mar 17, 2005 | 08:33 PM
kjc300's Avatar
kjc300
Right, I thought that you had the fours on the back!!! However, It still applies. The rear caliper is at the top and the bleed nipple is facing forwards(or backwards) and is not at the top so the air can sit higher than the nipple, therefore the pedal is always going to be spongy, thats why they need to be bled with the nipple at the top.
However it all depends on what you've done to the system as if you've only changed the fronts, then there should'nt really be air that far back!!
Old Mar 17, 2005 | 08:36 PM
James Raby's Avatar
James Raby
Aaaaaaaaaaaah, I just ran out and looked
The pic is of front calipers
Rears, the bleed nipple tilts backwards and yes the line DOES go in HIGHER than the nipple
But the guys said no air coming out, prob cos it can't get out!! LOL
Will get them to do it tomorrow, many MANY thanks
Old Mar 17, 2005 | 08:51 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Is that those Monkeys at the garage 'Down the Road' from you??
Well, at least they are cheap!!
Old Mar 17, 2005 | 08:54 PM
RichardPON's Avatar
RichardPON
......... and you didn't take it to APT because..........................?
Ah, maybe you were worried you'd get the job done right first time!
Old Mar 17, 2005 | 08:56 PM
James Raby's Avatar
James Raby
Ł45 an hour or whatever, plus fuel and time
Whole day in reality and over Ł70 down
Christian and Beccy
#1 in Spelling Club
No, Richard, its because we wouldn't do it for a Fiver and a portion of Chips.
Old Mar 17, 2005 | 08:57 PM
RichardPON's Avatar
RichardPON
Maccy D's chips, or McCain's home fries cooked and brought with in a thermos flask?
Old Mar 17, 2005 | 08:58 PM
Christian and Beccy
#1 in Spelling Club
Ah, but Ł40 per hour buys you someone that KNOWS that Bleed Nipples should be at the Highest point when Bleeding in order to remove the air and Load Proportioning Valves (if fitted) must be fully open. Also, that you should Bleed brakes starting at the furthest wheel from the Master Cylinder........
Old Mar 17, 2005 | 09:06 PM
James Raby's Avatar
James Raby
I know the furthest away bit, but I rekcon it's cos the rear line comes in higher than the bleed nipple
They good lads and this isn't the normal kind of car they work on
Not everyone has to go to a named company and spend more than they have too
Old Mar 17, 2005 | 09:07 PM
RichardPON's Avatar
RichardPON
That's very true.
You can go to an un-named company and spend more than you have to instead
Old Mar 17, 2005 | 09:09 PM
James Raby's Avatar
James Raby
Why would I havr to spend more? - they ain't gonna charge me for it
In all we agreed Ł20 would cover it, it's walking distance too
He dropped it off - said if ya can see what other's do with that set-up and we'll do it again tomorrow
At least I know it all fresh fluid LOL
Old Mar 17, 2005 | 09:38 PM
Adrian's Avatar
Adrian
That comment is kind of worrying...
Says to me that they aint got a clue and to ask someone who does (for free) and we will do it that way.
Old Mar 18, 2005 | 06:19 AM
James Raby's Avatar
James Raby
Well how many cars do you see with AP's up front and rear discs Ade?? not many in a normal gagarge.......
Old Mar 18, 2005 | 06:43 AM
adamS2RST's Avatar
adamS2RST
James, why didn't you just take it to APT?
Old Mar 18, 2005 | 07:28 AM
Eagle's Avatar
Eagle
Super Moderator
at rich
now im awaiting the next installment ...
they say i cant have discs on the back
sorry james
Old Mar 18, 2005 | 09:22 PM
James Raby's Avatar
James Raby
As requested
Old Mar 18, 2005 | 10:09 PM
Adrian's Avatar
Adrian
Brakes are brakes. Rear discs all over the place.
Any mechanic should know his/her way round bleeding.
I'll call my sister James, she might know more than the monkeys you are using!
c20tbo
Aug 17, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
