High torque YB starter motors
I'm converting my Sierra back to 2wd and need a starter motor, I was just going buy a standard part but whilst mooching on egay I noticed that a high torque more modern aftermarket version is available, anyone know anything about them and the origin of the part?? I don't mind buying one but they appear to be a Diesel starter with an adaptor bolted in place which isn't a problem other than I have loads of identical looking starters that were OE on Rover L series diesels!
struggling with reality
Diesel starter motors are high torque as they have to overcome the resistance created by a high compression engine! The thing that really makes the difference is a over specified battery.
Even if you have an improved starter motor you need a high spec battery to drive it!
In the winter when it is cold, the oil is thick, clearances are tighter, a good battery make ALL the difference. my daily is a 3 litre diesel and the new high spec battery makes such a difference! starts in half the time!
I would like to say yes , but the engine was a long time with out being cranked over as it went for a rebuild and so on , so I couldn't say 100%
But that said from what I can remember of it I would say yes it is better .
Hope this is of a help to you
2 litre transit starter is totaly differant, they have aside mounted front casing, same as the diesel mondeo's
Martin,
It has to be a Connect starter (1.8 litre diesel. 3 bolt fixing). They're designed for high torque to turn over a high compression diesel so spin over our low compression etrol engines with ease. They are a direct replacement bar maybe a terminal change on the exciter wire for the solenoid. These are all I fit on CVH's and Cossies now.
This is one...
http://www.ebay.co.uk/itm/TRANSIT-CO...item1e7b89c8e5
DavidK
27-09-2015 02:55 PM
