Which oil for S2 Rs turbo
Old 17-03-2005 | 04:07 PM
K18NEO's Avatar
K18NEO
Default Which oil for S2 Rs turbo
Hiya all!
Can you please help me out, im replacing a damaged sump on my rs, and need to change the oil.
Which oil is the best?
Thanks!
Old 17-03-2005 | 04:09 PM
Westy's Avatar
Westy
what oil was you using before
Mobil Motorsport or Castrol RS... cant go wrong
Old 17-03-2005 | 04:10 PM
K18NEO's Avatar
K18NEO
i dont know what oil before LOL
Thanks ill use castrol RS ... sounds good!
Old 17-03-2005 | 04:11 PM
adamS2RST's Avatar
adamS2RST
People will recommend silkoline. I have mobil 1 to go back in mine. will see how I get on. I'm sure "oilman" will see this thread and will be able to sort you out good advice
Old 17-03-2005 | 04:12 PM
James Raby's Avatar
James Raby
Oilman said Silkolene to me too, might get some
Old 17-03-2005 | 04:14 PM
K18NEO's Avatar
K18NEO
thanks!!
Old 17-03-2005 | 05:49 PM
Mobil motorsport 15w 50...
Old 17-03-2005 | 07:10 PM
The Sludge's Avatar
The Sludge
garibaldi
mobil 10 40
Old 17-03-2005 | 07:17 PM
ballin's Avatar
ballin
castrol rs 10w60
Old 17-03-2005 | 08:34 PM
sm's Avatar
sm
mobil 1 motorsport been usin it for years in erst's rs16i's etc and had no probs, normal mobil 1 is supposed to be for low milage engines
Old 17-03-2005 | 08:48 PM
James Raby's Avatar
James Raby
I simply asked Guy to explain this to me, and got this in reply
I percifically asked what would be the best oil
ANSWER
Your RST should take around 3.5 to 4.0 liters, so 1 x 5 Pro S 10w-50 liter delivered anywhere in the mainland UK £37.05 or 2 x 5 liter £70.25.
If you wish to order please call me on 01209 215164 office hours.
QUESTION
it might be good, but at double the price of me castrol, and how long before I need an oil change
ANSWER
Ok, no problem.
This oil is in a different league to the Castrol, and the Pro S does not need to be changed until 6000 to 9000 miles.
QUESTION
explain please, thought us having shonky CVH's needed oil changing at LEAST every 3000 miles or so??
am i mis-understood?
ANSWER
It works like this, petrolium based oil (Mineral multigrade, Semi synthetics and most full synthetics) have different size molecules in their base stocks, the smaller of the molecules get burned off quickly causing the oil to thin down, in addition depending on the quality of the addatives used they get used up quite quick hence the 3000 mile oil change. With a true synthetic where it uses no petrolium base stocks, made in a lab with all the molecules of uniform size (imagine empty egg boxes stacked on top of each other, then try and shear them apart - thats a true synthetic) if it was not for the addative deplition, these are the detergents and the VI improver being used up you would never have to change the oil, because the Silkolene uses top quality addative and base stocks it can go upto around 6000 to 9000 miles in RST, with other more modern cars it can go 12,000 miles +.
Hope this makes sense.
Old 17-03-2005 | 08:57 PM
DaveN's Avatar
DaveN
Valvoline Turbo V mate - semi synthetic i think for oil changes every 3000 and quite affordable also.
Old 17-03-2005 | 09:50 PM
K18NEO's Avatar
K18NEO
thanks mucho everyone!
Old 17-03-2005 | 09:56 PM
EIL132's Avatar
EIL132
Mobil 1 M/S. Proven
Old 17-03-2005 | 09:57 PM
K18NEO's Avatar
K18NEO
buying it tomorrow from Pj's
big_Rad
15-09-2017 09:36 AM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
cossirob
29-08-2015 03:23 PM
Quick Reply: Which oil for S2 Rs turbo
