rusty coloured coolant
What can you use to flush the cooling system out to stop the coolant going rusty? Cooling system has been flushed with water several times but after a while the goes rusty again.
As above the water rusts everything causing it to turn rusty colour you can buy engine flush but it will just happen again, depending what your running try waterless coolant
Take the rad off and shake out the rusty shit
It collects and can take ages to get it all out
But once everything is as clear as possible make sure the coolant is strong as its got rust inhibitors in
depends on the car, if the engine has a steel block then it will always form a little rust in the coolant
get an engine will an ally block, replace all cooling components and your done
2p..
I run a pinto in our track car and it doesn't help the fact the head is cast iron as well, mine was fully cleaned on the build then brand new pipes, coolant etc and I left it sitting for 3 months and when I started it the coolant was well brown, so flushed it through with new coolant but no doubt it will just happen again.
On mine it turned out to be the radiator.....
Flushed mine out with a garden hose whilst running engine, then filled up and drained, topeed up with pink coolant and it was perfect pink for 2 year before I stripped it for rebuild
07-10-2015 12:56 PM
