big power focus rs
You nutter!!
give paul a bell, failing that give clarkee a bell, devils car hooked up proper at central, bollocks to that only eunning 300 odd brake, it was spinning them slick in third lol, thats all i can say though, never had the chance to have 550bhp car boo hiss
iam sure ian howell used a tvr or aston martin ap racing clutch in the focus , but you've got quarter masters , tilton , helix or have a word with ttv racing who make flywheels as they now custom build clutches.
whats the car for just drag racing or track day or all the above ?
clutch size of 240mm I would get a flywheel and go for 185mm as tilton for example have a clutch rated at 620lb-ft for £456 or thinking about it I think a cosworth clutch is 240mm so along as the splines are the same you could try one of them .
will look into the others tho.
ZETEC TURBO
The Sachs is a normal style plate.it can take more torque than the ap 6 paddle setup.using my phone at the moment so can't do links. If you do a search for focus rs clutches on here there is a post i done with links for the Sachs kits. Will find some links tomorrow for you though
Another big up for the Sachs unsprung 4 paddle, give competition
braking products a ring mate.
+44 (0)1748 830909
+44 (0)1748 830909
Bodger of Blackburn
i tried the cosworth plate and frs cover, it didn't work well, may have been the cover was weak, still got it though under the bench, wouldn't hold more than 12psi of boost on the gt30, a new paddle kit from AP held 2.2 BAR, so 32psi without slipping.
09-10-2015 07:38 PM
track.focus'd
12-08-2015 05:53 PM
