Focus rs bits on zetec turbo???
Hello can anyone tell me if genuine ford focus rs head bolts fit a silver top zetec turbo as I'm fitting a frs head gasket ???
And someone told me you can play around with different ford cams to get more driveability ?? Which ones??
Mines a 2.0 silver top
cant rember on the bolts.
Yes you can fit say 1.8 blacktop cams into a rs engine as for knowing what it will do i dont know but i read about a rs in performance ford awhile ago using a 1.8 inlet cam iirc with 500bhp and he said it created more bottom end.
I know the silvertop head gasnet fits the blacktop. I did that myself so I dont see why it won't work other way... As for head bolts surely as head gaskets are same they should fit..?
This is an old thread, mines already built now
I used focus rs gaskets and silvertop bolts and new cambelt and water pump ect and fitted devil developments valve springs while it was apart, just need injectors and a turbo and then I have everything
Engine Machinist
all zetec (and duratec ST/RS) headgaskets and bolts are interchangeable really, most companies only sell 3 layer MLS gaskets (0.6mm thick) to fit all late models, but there are thicker ones available.
you can fit a black top gasket onto silvertop and if you really wanted to (although i have no idea why you ever would), you can fit a silvertop gasket to a black top.
Bolts are the same on all models.
