subs, fit and forget types
right then, got the urge to put some bass into my car after looking at that mondeo at ace cafe over the weekend
i've currently got one of those flat amps with built in subs stuck in the corner of the boot as i needed to keep it fairly boot friendly, but now i don't need to i just want something that will potentially fill the boot and potentially shake the windows out![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
can i buy something off the shelf or is it better to have a custom instal?
i want to be able to remove it though if i need to so it can't be too custom so that it won't come out of the boot opening
cheers
cheers
Thats easy then bud, as mr wishy says mount the amp somewhere solid but out of the way like behind a rear panel.
You can have as large or small a box as you like that can be lifted in or out with a simple two wire push fit plug.
With the amp hidden and the box removed there would be no sign of anything fitted and more importantly no loss of space.
Simples
Simples
Buy an active box or tube as you wont need a separate location for the amp then.
Hard wire said box or tube via a quick connector as previously discussed.
I had an earthquake twin 12" box and mounted the amp to it so it was removed as a kit.
Received 1,044 Likes
Them grey fli bass boxes are ok.My mrs has one in her boot.The standard amp stopped working and the original sub split.Ive fitted a amp on the back of the box and fitted a new fli sub.Ive put spade connectors on the live/earth and remote wires so i can easily disconnect them.
Lol , almost
Active means an all in one type package like the vibe,fli in phase offerings where the amp is built in to the box.
They do serve a purpose as they are easy to install and good for people with limited space.
JoeyBoyden
18-08-2015 10:52 PM
track.focus'd
12-08-2015 05:53 PM
