ford escort mk6/7 engine conversion
hi i have just bought myself a
FORD ESCORT 1.3LTR MK6/7 3door
i bought it to do an engine conversion on but i carnt decide weather to put a
1.8GTI ENGINE IN OR A 2.0 RS2000.
but i also want to put a turbo on it aswell but wot engine wud be best or easyest to put a turbo on
so im basicly just trying to get sum advice on these things so if any1 can help i wud be very grateful .
2 different engines bud/ 2ltr silvertop from mondeo and 2ltr blacktop from focus and mondeo both good engines and both cost around same to turbo and both easy to fit! Depends what you want to do and how much you want to spend! Cheap route is st170 bottom end with standard forged internals with blacktop head using either frs inlet and injector rail/rover inlet and injecto rail and exhaust manifolds with frs turbo or use rst manifold with adaptor plate and T3 turbo
Hope you have very deep pockets as a big Zetec Turbo build will cost loads. Not just the engine but the gearbox, clutch and chassis will all need significant attention.
No such thing as a Mk7 Escort, they ceased on the Mk6 where the Focus was introduced
matman
09-09-2015 05:45 PM
