Brake disk/pad cooling
#121
Chip, with regards to the 4 or 6 pot...is the pad coverage from the 6 pot not overly much on a 300mm disc?
I can remember the hassle 'back in the day' when people tried running twin caliper(increasing pad coverage) and ended up just overheating the discs.
Would running the same setup with a different compound pad end up putting so much heat into the disc that they could potential fail?
Nevsrevs, cheers for taking the time to post your pics, roughly the same as I am planning other than the bit where it gets to the brakes themselves.
#122
Had a decent look at the weekend and the logistics of attaching a cooling duct to the hub isnt looking promising, is the amount of distance it moves during steering that is the problemm it moves about a foot and it gets to within a few inches of the bottom pulley so the pipe is going to have to continually compress and expand between a short compressed size and about 300% as long when steering the other way.
Normal ducting could easily end up bending into the shaft if I do that.
Might try and just attach to the bottom wishbone pointing at the middle of the disk as best I can initially and see from how I get on if its worth trying the other way or not.
#124
Lol, yeah that would do it.
TBH I think just the pad change is probably going to sort me out anyway, so will see how it is when im out next before deciding where to go next, seems like the simplest (although not cheapest) option might be some decent curved vane disks if its not good enough now.
#126
Will see when Im next out Jay, dont forget it wasnt too far off good enough before on just yellowstuff pads.
House move appears to be happening now hopefully based on feedback from the chain, so car will be on the back burner for a couple of months anyway.
#127
just finding my feet
I honestly recommend trying sintered pads if it pad fade you are getting,,, sintered pads don't have pad fade at all but are very sharp
Also my missus family work at general mogal (ferodo ) and I'm asking one of them to get some pad info for me for impreza so I might get some real tech help from there team,,, or the other factory in India lol
#128
The problem with pads that dont fade, is the disks get too hot and warp then, thats what was happening on the old 280mm disks with pagid blue pads, I had no fade, but it kept wrecking disks, like literally in a day if you used it really hard.
Again, better disks probably the answer for that, so if I get that issue on the ds2500, I will have no choice but to put my hand in my pocket for 500 quid of disks or whatever.
Not the end of the world, but would have been nicer to get away with 70 quid ones! lol
#129
Why are the disks warping? Generally it's a total myth and its due to pad deposits or uneven heating when you stop, meaning you probably need to cool them more before coming in.
#131
Heat cycles do warps discs,,, admittedly most road driving is puddles or binding calipers but track use gives heat cycles too
Brake ducts obv are the try then if pad fade use sintered pads or if disc then floating bells
If your not hard on brakes then its got to be ventilation due to wheels and heat transfer though I fear it's a mix and 300bhp is a lot to ask of a 280 disc and sliding calliper
Next issue will be the front brakes kicking in the ABS like my impreza due to locking the odd wheel
Ps: I have enjoyed this thread,,,, listening to people's ideas ect just like the old days
#133
I would imagine cause they arent seeing even temperatures at some point, possibly from stuff like when sessions get red flagged and you have to stop suddenly etc.
Ive spoken to a guy on the Clio forum who sources a lot brakes for people and he reckons that the EBC Gold disks are actually of decent construction and have curved vanes in them and will cool significantly better than the cheapy ones I have on there at the moment.
Only about 160 quid a pair, and available in exactly the fitment I am using currently, so well worth a go before committing myself to 500+ in bell and rotor ones I reckon.
#134
#135
On a track though, you have no real control over how it gets heated or cooled. That's dictated by the track itself, and the driver. But no easy way to actually control it.
#136
Testing the future
all Chip has to do in reality is brake earlier and not as hard and maybe not accelerate as hard as possible and he wouldn't have a problem - but where's the fun in that?
#137
Without a live temperature monitor...you still dont know what they are though in order to try to control them.
And you still have no solid way of controlling them from cold-glowing-cold again. The only thing you can be sure of, is they will get heated up a hell of a lot faster than they will cool down.
#139
Also the red flag thing is a big issue, I always make sure I do a cool down lap (or perhaps half lap if I am out at bedford on the full circuit as its so long) but if you get suddenly brought to a halt on a red flag you have no option but to sit with red hot brakes while you are stationary
Like here:
Im driving at trackday pace and then suddenly have to come to an unexpected halt and then was sat there for 10 mins or so while they cleared up wreckage off the track from a crash.
Like here:
#141
chip i havnt read all the way through so dont know if its been covered in more depth, but i was going to sugest water cooling, noticed it was mentioned on the first page. sounds outlandish but its common, if not std practice on racing trucks. dont know if youve ever noticed clouds of steam coming from the front wheels off trucks on track?
i spoke to a chap at outlon a couple of years ago who ran one of these types of trucks with the water cooling, iirc the water is fed inside the disk between the two braking surfaces from the centre and is turned to steam and flung through the vents and out of the edges of the disc. its something ive thought about having a play with, would be mega cheap and easy to install a basic setup and just see how it goes. could easily just get a decent size washer bottle, some copper pipe and cobble something together as a trial. not really that nessecary on a 125bhp puma but on your clio it might be worthwhile in my opinion.
#142
Ben
So it seems like the solution is, people need to stop crashing?
Fascinating thread, really enjoyed reading this.
#143
Thats interesting XR-Stu.
Might be worth considering, although tricky to know what strategy to use to activate it.
I guess brake lights would be simpest way, but obviously the problem with that is the time you need to cool them most is probably just before you start to brake not when you are actually braking as by then its kind of too late if the disks are too hot already from the last application of the brakes.
#144
Have you seem the size water tanks the trucks use though, chip you was at bhp the other week you might have seen the 6 water tanks and the water trail they left driving off the track
I ain't sure if its to regulate the disc temp to reduce warp due to stupid heat cycles a big lorry would give must warp discs rather than cooling the pads
The size of the tank is the issue though I would have thought
#148
The water should never see any further than the brake disc itself though, and it would only be a very fine spray, much like water injection for the engine.
But spraying water onto a red hot surface will of course have a negative side too.
I think the keeping it simple solution is the best.
#149
#151
http://www.willallracing.com.au/gtrbrakes.htm
This is quite interesting and I'm sure you could write a program to measure speed ect
Might be a interesting idea
#152
But one thing is certain, and thats water WOULD drop the temps of the disk, its incredible at mopping up heat.
#153
Most simple form would be a pump, couple of small water injection nozzles and turn the pump off/on based on brake pressure via a pressure switch.
Simple brake switch would be doable too, but would spray more often.
Or get a relay/switch based on roadspeed and brake pedal input.
Would be lots of trial and error as usual though
#155
The trucks might pump gallons of water through their brakes but I don't think you'll need that amount on the Clio. Should be able to rig up a relay to activate them while the pedal is pressed (brake light) then stay on for a few seconds afterwards. Just like on a lot of cars when you press the windscreen washer switch the wipers will stay on and so 3 or 4 sweeps of the screen afterwards. Same principle. Not sure how those circuits work but you may even be able to pikey something using an existing relay or a scrapyard job.
#156
Testing the future
